Browse Forums Flooring & Floor Covering Re: Laminate flooring making 5Sep 25, 2017 3:20 pm kirashogun Real wooden floors are glued down to the subfloor so nothing moves. Laminate can be floating floors with nothing tying them down other the interlock grooves between each plank. As they expand and contract with heat, these floors can get a bit tight and cause friction between each plank hence you will have these crackling sound when you walk over them. Thanks.. In my case, when it gets cold, the crackling sound becomes more obvious.. Does it happen to every home with laminate floating boards? (I don't think it does, as none of my friends has got this issue) Is there any way to fix this problem? Would reinstalling the planks help? Re: Laminate flooring making "clicking" sound when walked on 6Sep 26, 2017 8:53 am Well if your friend has real wood floor then that’s expected. If they have laminate, it’s possible although not common to glue down the planks to solve the squeaky floor problem. Reason why laminate don’t usually do this is because it’s usually a budget product and you want to reduce your labour cost. For you, you will need to rip the floor up and relay using glue. Not a cheap proposition as the labour would cost possibly more than the laminate. Re: Laminate flooring making 7Sep 26, 2017 10:00 pm kirashogun Well if your friend has real wood floor then that’s expected. If they have laminate, it’s possible although not common to glue down the planks to solve the squeaky floor problem. Reason why laminate don’t usually do this is because it’s usually a budget product and you want to reduce your labour cost. For you, you will need to rip the floor up and relay using glue. Not a cheap proposition as the labour would cost possibly more than the laminate. Thanks.. So for laminate floors, is it common to have the same problem (crackling sound from seams) that I'm having with my laminate floor? My friends mentioned above all have laminate floors and none of them has this problem.. Re: Laminate flooring making "clicking" sound when walked on 8May 24, 2021 9:25 pm I have the same experience, newly laid. I think its pretty common especially if the subfloor is not flat..its annoying but not something that i cant live with Are you still experiencing the issue? Or did you get them fixed somehow.. Just about completed a renovation project and hit a small issue that we didn’t see We have laminate floors now where we had tiles before (turned out it was actually 2… 0 5324 Yes, Im following your Lindfield build, looks amazing. 4 2661 Hi We have a road close to our place and only an old flimsy wooden fence between us and the Neighbour closest to the road. Any ideas on a sound proof modular fence. Like… 0 7787 |
