Browse Forums Owner Builder Forum Re: Owner Build in Southern Flinders Ranges- Cert of Occupan 203Mar 18, 2017 5:12 pm Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Re: Owner Build in Southern Flinders Ranges- Cert of Occupan 210Mar 25, 2017 7:40 am Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Re: Owner Build in Southern Flinders Ranges- Cert of Occupan 214Apr 17, 2017 8:09 am Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Re: Owner Build in Southern Flinders Ranges- Cert of Occupan 217Apr 28, 2017 6:11 am Build thread http://tinyurl.com/llgc7yk Re: Owner Build in Southern Flinders Ranges- Cert of Occupan 219Jun 05, 2017 10:34 pm Hi Beetaloo, I'll be interested to see how it goes through the winter. We finally have our DA into council to do an owner build ourselves. E are going to do a knock down rebuild. I've incorporated such things as 900mm eaves, double glazing, zones within the house and living areas facing north etc. Once I get the approval I intend to start an ongoing blog as the build progresses. We bought a pop top caravan today to use as a site office and occasional stay over. I'm in Belrose in Sydney and fortunately hardware and the like are just up the road not 160kms away 🤗 Re: Owner Build in Southern Flinders Ranges - Weatherboard C 220Jun 14, 2017 1:15 pm Beetaloo Starting installing weatherboard cladding - 150mm Linea Scyon I found the boards (16mm thick) difficult to cut. Saw blades were wearing out in a couple of hours. I tried both cheap blades & expensive genuine blades. They all wore out quickly. The genuine blades did last a bit longer. In desperation when I had run out of blades one weekend, I tried an old rusty +40 year old blade. It worked a treat. I was able to complete all the remaining cladding using this one blade. (Its teeth are different to the new blades. There are 2 rows of teeth) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'm going to dig up a old post. I note that Linea Scyont comes only comes in 4200mm lengths. How did you join the Linea Scyon planks? Are the joins visable for a couple of metres? And lastly, was the trim difficult to get right in terms of installation, window flashing and corners. Congratulations! Nice to put that to bed before christmas, now you can relax 3 7373 We are in NSW and require 2 positive covenants to be placed on the property didnt really underdtand this but apparently it will take a few months, and have just been… 2 7616 0 5801 |
