Browse Forums General Discussion 1 Mar 21, 2017 9:48 am _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Leaking Ensuite? 2Mar 21, 2017 9:55 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Leaking Ensuite? 4Mar 21, 2017 10:05 am _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Leaking Ensuite? 5Mar 21, 2017 10:15 am _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Leaking Ensuite? 9Mar 21, 2017 11:23 am _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Leaking Ensuite? 10Mar 21, 2017 11:25 am _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Leaking Ensuite? 11Mar 21, 2017 11:26 am _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Leaking Ensuite? 13Mar 21, 2017 11:53 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Leaking Ensuite? 14Mar 21, 2017 12:02 pm _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Leaking Ensuite? 20Apr 08, 2017 12:08 pm Sometimes even a inch of missed gaulking will mean big water problems, get to ground level to check shower, also some builders only water proof shower area etc, don't do total area, smaller builders generally put more. Money behind walls etc, you don't see this and it's one of the biggest differences. DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24432 My first suspect area is at the bottom of the harvested downpipe furthest from the tank. PVC downpipes expand and contract with heat and cold, putting pressure on the… 3 1176 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 12475 |
