Browse Forums Building A New House Re: Tile company charging for different tile lay pattern 2Mar 21, 2017 10:43 pm Follow our first house build here! -> https://forum.homeone.com.au/viewtopic.php?f=31&t=86484 Re: Tile company charging for different tile lay pattern 4Mar 22, 2017 7:16 am Building the simonds palisade in gippsland Re: Tile company charging for different tile lay pattern 9Mar 22, 2017 10:45 pm Follow our first house build here! -> https://forum.homeone.com.au/viewtopic.php?f=31&t=86484 Re: Tile company charging for different tile lay pattern 11Mar 23, 2017 9:02 am Building the simonds palisade in gippsland Re: Tile company charging for different tile lay pattern 13Mar 23, 2017 9:15 pm Follow our first house build here! -> https://forum.homeone.com.au/viewtopic.php?f=31&t=86484 Re: Tile company charging for different tile lay pattern 17Mar 24, 2017 8:02 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Tile company charging for different tile lay pattern 18Mar 31, 2017 2:39 pm Follow our first house build here! -> https://forum.homeone.com.au/viewtopic.php?f=31&t=86484 Re: Tile company charging for different tile lay pattern 19Mar 31, 2017 2:40 pm StructuralBIMGuy Interesting topic Even if you are DIYing or getting quotes from a tile contractor It's important to have a fair idea of what's involved regarding Rates,Material, Labour and Plant,etc,etc in order to work out a fair price 3D Simulations of tile laying patterns and their data can be automated using apps Here's' a sobering post in which I am critical of 3D rendering software packages that gives you Photo realistic (light rendering) images of what your tiling will look like when your tiling project is finished..but simulations for Cost analysis & Optimisation are ignored by designers, Tilers & Builders.. 2 guesses why the battlers and punters are keep in the dark on costs? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks, that looks helpful... I keep dreaming of DIY, but alas no time or skill or experience... Follow our first house build here! -> https://forum.homeone.com.au/viewtopic.php?f=31&t=86484 Generally, the texture that you listed will have a 2mm size stone chip in it which is dragged with float to give the lines Any patch work needs to be 2mm less than face… 2 1912 It is true that a builder can ignore your independent inspection report as it is not part of the contractual arrangement but that is stupid because he cannot avoid fixing… 9 47325 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5470 |
