Browse Forums Building A New House Re: Ryalls - Coral Homes Noosa 26 - D0dgy Grout? 2802Mar 14, 2017 9:04 am _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Ryalls - Coral Homes Noosa 26 - D0dgy Grout? 2803Mar 14, 2017 9:05 am _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Ryalls - Coral Homes Noosa 26 - D0dgy Grout? 2804Mar 14, 2017 9:09 am _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Ryalls - Coral Homes Noosa 26 - D0dgy Grout? 2805Mar 14, 2017 9:12 am _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Ryalls - Coral Homes Noosa 26 - D0dgy Grout? 2806Mar 14, 2017 9:15 am _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Ryalls - Coral Homes Noosa 26 - D0dgy Grout? 2807Mar 14, 2017 9:17 am _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Ryalls - Coral Homes Noosa 26 - D0dgy Grout? 2808Mar 14, 2017 9:19 am _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Ryalls - Coral Homes Noosa 26 - D0dgy Grout? 2810Mar 14, 2017 4:08 pm M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Ryalls - Coral Homes Noosa 26 - D0dgy Grout? 2812Mar 20, 2017 4:38 pm _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Ryalls - Coral Homes Noosa 26 - D0dgy Grout? 2813Mar 20, 2017 4:40 pm _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Ryalls - Coral Homes Noosa 26 - D0dgy Grout? 2815Mar 20, 2017 7:11 pm _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Ryalls - Coral Homes Noosa 26 - D0dgy Grout? 2817Mar 20, 2017 8:08 pm BrownDog77 Ryalls_first_build BrownDog77 [quote="Ryalls_first_build"][quote="BrownDog77"]Just a quick question re: your retaining wall is it 1m from your boundary? We've been told lake Mac now require all retaining walls 1m from fence line which means what we'd hoped to be the skinny side of house now needs to be not quite so skinny Sorry BD just seen this! Ours is 30cm from the boundary. It does say that they have to be 1m but will take into consideration anything less.. stupid coral probably didnt even realise that was the rule and just did it anyway, We didnt have any issues with it. Strange though as i know houses in cameron park have them on the boundary, which would be my preference Lol it was Coral that told me about the 1m it came into effect due to Cameron Pk being on boundary & some apparently are falling down & tricky as to which sides at fault Gee what a bunch of idiots.. they might be right but id call council if i were you [/quote] I think I might actually try & get an Appt with council with all our plans & contour & just see what they advise so I know what's expected that way we know what they require before plans are sent & we don't waste time being rejected lol [/quote] Yes definitely do it! We ended up meeting with council after being rejected as coral tried to stand their ground with council _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Ryalls - Coral Homes Noosa 26 - D0dgy Grout? 2818Mar 20, 2017 9:58 pm Our plans were rejected and the house had to be moved across to allow the 1m for the retaining wall. As it turned out the way the site was cut we did the retaining wall on the boundary for about 9m (otherwise it would be almost hitting the house!) and then went out to a metre where we could. The assessor who came to do our inspection for the occupancy certificate (who was a douche) was like well that won't pass, that's not what's on the plans and against council code blah blah blah If we ever go to sell we'll just get it passed by council then. Oh and we are in Cameron Park. Re: Ryalls - Coral Homes Noosa 26 - D0dgy Grout? 2819Mar 21, 2017 5:56 am Have you seen how close next door's retaining is to our boundary Ryalls? No way that's a metre. Going to make fencing hard I think. Re: Ryalls - Coral Homes Noosa 26 - D0dgy Grout? 2820Mar 21, 2017 8:20 am Not sure about the rule in NSW but here in Victoria; We can have retaining on boundary but needs council permit and engineering report Retaining not on boundary - the height of the retaining wall should not exceed the distance between the wall and the boundary fence.. (so you can build a 20 cm high retaining at 20 cm from the boundary) DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13781 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 4357 |
