Browse Forums Renovation + Home Improvement Re: Quoting for a renovation? 4Mar 20, 2017 12:41 pm fatalle424 Good point, no I am not. It really comes down to what your time is worth. Have decided on your hourly rate and laid out an estimate of time for each task? Generally if it's labour only I'd calc time for floor seperate, stairs seperate, doors etc, etc. Once u have you a total estimated amount of hours times that by your rate ( generally here in Sydney that will range between $75 - $95 per hour if you are licensed and insured, and based on your experience). Don't forget to add in a few extra hours for those unforseen items as well. Once you have your total then add a 20 - 30% margin on top to cover your profit. With out seeing the job it sounds like at least a weeks worth of work, so I'd say you may be a bit light on, but then again if it's for a mate then mates rates need to apply Good luck with it! Kind Regards James Mason - Our Build. www.renovationjunkies.com.au www.ourbuildhandyman.com.au Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5759 Coming back to your old stomping grounds, huh? Renovations on a budget can be quite the journey. It's like giving your house a new lease on life. The twist of not knowing… 1 3578 Assuming the structure of your cabinetry is good then I would DIY everything as follows: - replace your counter tops entirely, - replace all drawer runners with soft close… 1 4919 |
