Browse Forums Building A New House Re: Building Metricon Glendale 42 Limited Edition in Geelong 2405Mar 17, 2017 4:49 am Nev _________________ Blog | ( will start once received tender ) H1 thread | https://forum.homeone.com.au/viewtopic.php?f=31&t=77665 Re: Building Metricon Glendale 42 Limited Edition in Geelong 2408Mar 17, 2017 12:51 pm Orpheus kylz4 Yeah ours is very minimal. Have you got a closer pic? Could they not put a little slope under the carpet so there was no straight up step?? Just this one. I've seen it in all M display homes. However this is not the case with other display homes in NSW. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Think of it, would make sense for bath to be step down to reduce possibility of water spillage.. Re: Building Metricon Glendale 42 Limited Edition in Geelong 2409Mar 17, 2017 4:35 pm Spotme Orpheus kylz4 Yeah ours is very minimal. Have you got a closer pic? Could they not put a little slope under the carpet so there was no straight up step?? Just this one. I've seen it in all M display homes. However this is not the case with other display homes in NSW. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Think of it, would make sense for bath to be step down to reduce possibility of water spillage.. I prefer same height. The reason why it's a step up is because the tilers have to do screeding to adjust the floor level so it slopes towards the drainage hole. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building Metricon Glendale 42 Limited Edition in Geelong 2410Mar 17, 2017 4:58 pm Kylz how did PCI go? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building Metricon Glendale 42 Limited Edition in Geelong 2412Mar 17, 2017 6:13 pm Thanks for asking Orph and Emmz, but.... Pffft, have to do it again in a few weeks as there was too much not finished off! We thought it was just external painting, render to front piers and blinds to go so went ahead with it but inspector found A LOT more issues and had a go at site manager!! Think he will get in a bit of trouble when report goes through!! Hoping they will push through issues and have re inspection in a few weeks and then there should barely be any defects and handover should be quite quick! ??? Re: Building Metricon Glendale 42 Limited Edition in Geelong 2413Mar 17, 2017 6:53 pm kylz4 Thanks for asking Orph and Emmz, but.... Pffft, have to do it again in a few weeks as there was too much not finished off! We thought it was just external painting, render to front piers and blinds to go so went ahead with it but inspector found A LOT more issues and had a go at site manager!! Think he will get in a bit of trouble when report goes through!! Hoping they will push through issues and have re inspection in a few weeks and then there should barely be any defects and handover should be quite quick! ??? Awww Kylz!! Hoping all the issues get dealt with quickly Bit of a setback but hopefully he makes yours a priority Re: Building Metricon Glendale 42 Limited Edition in Geelong 2414Mar 17, 2017 7:10 pm kylz4 Thanks for asking Orph and Emmz, but.... Pffft, have to do it again in a few weeks as there was too much not finished off! We thought it was just external painting, render to front piers and blinds to go so went ahead with it but inspector found A LOT more issues and had a go at site manager!! Think he will get in a bit of trouble when report goes through!! Hoping they will push through issues and have re inspection in a few weeks and then there should barely be any defects and handover should be quite quick! ??? That's ok Kylz, we can do PCI together again! Did yr SM tell you if the QA passed or not? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building Metricon Glendale 42 Limited Edition in Geelong 2415Mar 17, 2017 7:29 pm Orpheus kylz4 Thanks for asking Orph and Emmz, but.... Pffft, have to do it again in a few weeks as there was too much not finished off! We thought it was just external painting, render to front piers and blinds to go so went ahead with it but inspector found A LOT more issues and had a go at site manager!! Think he will get in a bit of trouble when report goes through!! Hoping they will push through issues and have re inspection in a few weeks and then there should barely be any defects and handover should be quite quick! ??? That's ok Kylz, we can do PCI together again! Did yr SM tell you if the QA passed or not? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Lol that is true Orph No he didn't say anything about passing QA! I'm just hoping he gets traded back quickly to do fix ups so we can try again! Re: Building Metricon Glendale 42 Limited Edition in Geelong 2416Mar 17, 2017 7:33 pm kylz4 Orpheus kylz4 Thanks for asking Orph and Emmz, but.... Pffft, have to do it again in a few weeks as there was too much not finished off! We thought it was just external painting, render to front piers and blinds to go so went ahead with it but inspector found A LOT more issues and had a go at site manager!! Think he will get in a bit of trouble when report goes through!! Hoping they will push through issues and have re inspection in a few weeks and then there should barely be any defects and handover should be quite quick! ??? That's ok Kylz, we can do PCI together again! Did yr SM tell you if the QA passed or not? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Lol that is true Orph No he didn't say anything about passing QA! I'm just hoping he gets traded back quickly to do fix ups so we can try again! Ha! We have been going around PCI for 3 months so 2 weeks delay is not too bad @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building Metricon Glendale 42 Limited Edition in Geelong 2417Mar 17, 2017 7:37 pm Orpheus kylz4 Orpheus [quote="kylz4"]Thanks for asking Orph and Emmz, but.... Pffft, have to do it again in a few weeks as there was too much not finished off! We thought it was just external painting, render to front piers and blinds to go so went ahead with it but inspector found A LOT more issues and had a go at site manager!! Think he will get in a bit of trouble when report goes through!! Hoping they will push through issues and have re inspection in a few weeks and then there should barely be any defects and handover should be quite quick! ??? That's ok Kylz, we can do PCI together again! Did yr SM tell you if the QA passed or not? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Lol that is true Orph No he didn't say anything about passing QA! I'm just hoping he gets traded back quickly to do fix ups so we can try again! Ha! We have been going around PCI for 3 months so 2 weeks delay is not too bad @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] I seriously don't know how you've done it and stayed so calm! You are one of a kind lol I'm just hoping it will only be 2-3 weeks, never bloody know I guess Re: Building Metricon Glendale 42 Limited Edition in Geelong 2418Mar 17, 2017 7:38 pm Emmz70 kylz4 Thanks for asking Orph and Emmz, but.... Pffft, have to do it again in a few weeks as there was too much not finished off! We thought it was just external painting, render to front piers and blinds to go so went ahead with it but inspector found A LOT more issues and had a go at site manager!! Think he will get in a bit of trouble when report goes through!! Hoping they will push through issues and have re inspection in a few weeks and then there should barely be any defects and handover should be quite quick! ??? Awww Kylz!! Hoping all the issues get dealt with quickly Bit of a setback but hopefully he makes yours a priority Thanks Emmz I really hope so!! Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 12804 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 9709 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 19766 |
