Browse Forums Landscape & Garden Design Re: Landscape Inspiration & Design Concepts 384Feb 18, 2017 12:56 pm Just found a breakfast bench stool I like Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our Nolan viewtopic.php?p=1516376%23p1516376 Re: Landscape Inspiration & Design Concepts 385Feb 18, 2017 12:57 pm leelee116 Just found a breakfast bench stool I like Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our Nolan viewtopic.php?p=1516376%23p1516376 Wrong thread Lee! @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Landscape Inspiration & Design Concepts 387Feb 18, 2017 7:26 pm Found our letterbox. Company is in WA so it's a custom order. We liked the colour scheme of this plate and rendered wall. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Metal insert is extra: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Landscape Inspiration & Design Concepts 388Feb 18, 2017 7:46 pm Love that Orph!!! Who will build the rendered wall for it? Re: Landscape Inspiration & Design Concepts 389Feb 18, 2017 7:48 pm kylz4 Love that Orph!!! Who will build the rendered wall for it? Thnx Kylz. Our landscaper ofc since he's doing the rest of our retaining wall. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Landscape Inspiration & Design Concepts 390Feb 18, 2017 7:53 pm Oh I didn't realise you were doing retaining wall lol. Nice Re: Landscape Inspiration & Design Concepts 391Feb 18, 2017 7:55 pm kylz4 Oh I didn't realise you were doing retaining wall lol. Nice Don't even mention our retaining wall as it alone costs us $30k (biggest component) of our Landscape budget.... @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Landscape Inspiration & Design Concepts 394Feb 19, 2017 8:28 pm Ouch orph! We are looking at materials and the like for retaining walls at our place. We have about 1.2m high to retain in front our bedroom windows (at the front of the house) and about 1.4m high required along the side boundary (30mtrs long) and across the back of our house. - otherwise known as Kym - Re: Landscape Inspiration & Design Concepts 395Feb 19, 2017 8:36 pm Oops. Pressed enter too early. At this stage we are looking at http://www.quickstone.com.au Each block weighs between 500-700kg so once in place it won't be going anywhere. And it also means we wouldn't need a concrete footing as it uses crushed and compacted road base type stuff. We do have close to two pallets of bricks left over so we are considering using them to do the front retaining and then having a go at rendering ourselves - otherwise known as Kym - Re: Landscape Inspiration & Design Concepts 396Feb 19, 2017 8:58 pm needsausername Oops. Pressed enter too early. At this stage we are looking at http://www.quickstone.com.au Each block weighs between 500-700kg so once in place it won't be going anywhere. And it also means we wouldn't need a concrete footing as it uses crushed and compacted road base type stuff. We do have close to two pallets of bricks left over so we are considering using them to do the front retaining and then having a go at rendering ourselves So how much is the cost for your retaining wall? Would like to compare to ours @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Landscape Inspiration & Design Concepts 397Feb 19, 2017 9:00 pm We are just going through costs this week. We've finally come up with a landscape design we like. I'll be sure to let you know orph! My thinking is, it's going to be enough to run a small country for a few years - otherwise known as Kym - Re: Landscape Inspiration & Design Concepts 398Feb 19, 2017 9:06 pm needsausername Oops. Pressed enter too early. At this stage we are looking at http://www.quickstone.com.au Each block weighs between 500-700kg so once in place it won't be going anywhere. And it also means we wouldn't need a concrete footing as it uses crushed and compacted road base type stuff. We do have close to two pallets of bricks left over so we are considering using them to do the front retaining and then having a go at rendering ourselves Do you know what the delivery fee is from nowra where their located Re: Landscape Inspiration & Design Concepts 399Feb 19, 2017 9:14 pm Not too sure sorry Sandra. We are building on the fringes of Jervis Bay so it's fairly close to us. Where abouts are you? - otherwise known as Kym - Re: Landscape Inspiration & Design Concepts 400Feb 19, 2017 9:15 pm needsausername Oops. Pressed enter too early. At this stage we are looking at http://www.quickstone.com.au Each block weighs between 500-700kg so once in place it won't be going anywhere. And it also means we wouldn't need a concrete footing as it uses crushed and compacted road base type stuff. We do have close to two pallets of bricks left over so we are considering using them to do the front retaining and then having a go at rendering ourselves Are you laying these via a hi-ab Crane? Landscape Design Parramatta We have been doing a large amount of landscape design work in Sydney… 0 3 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25382 Thanks very much! And would the landscaper/contractor generally involve the engineer or is that something the client would do? Thanks for your help 2 10448 |
