Browse Forums Building A New House Re: Carlisle homes site cost -additional $11k- infill after 10Feb 02, 2017 7:10 am macca134 nikil We have almost $5,000 charge for 75mm of fill with PD. Thanking you - These volume builders know how to hit thats for sure. I couldn't believe it, 75mm is nothing!!! We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37150 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5241 Our standard double-glazed window is tested to achieve, Rw 34, and can be glazed to suit Rw 39. The price is good too... 3 9476 |
