Browse Forums Renovation + Home Improvement Re: How to remove spray paint from floor 2Jan 10, 2017 7:34 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How to remove spray paint from floor 4Jan 26, 2017 2:51 pm Paint thinner is generally a sure win when it comes to removing paint, but like some of the other guys here have said, it depends on what paint you've been using. And again, try whatever solvent you've got on a small portion in a corner somewhere just in case you end up smearing the paint all over the place. Keep us updated on how things go though! Word to the wise - be prepared to use a lot of elbow grease while you're at it! Re: How to remove spray paint from floor 5Mar 17, 2017 4:06 pm Agree with Cameron. Paint thinner would be the best solution to remove paint. We needed spray painting for our home improvement and it was scheduled next week with http://www.easternbeachespainting.com.au/ They just called me saying they can do the job though they are from Sydney. You can check them for house painting and decorating needs. Cheers! buildX Re: How to remove spray paint from floor 6Mar 19, 2017 11:50 am Hi before you use those harsh chemicals please try Eucalyptus oil. not a cheap nasty one but the Thursday island one will work. Put some on a clean rag and rub the area. Smells delish too lol Re: How to remove spray paint from floor 7Mar 28, 2017 7:40 pm Agree with Cameron. Also, you can try Methyl Ethyl Ketone, and a wire brush. Use old towels/rags to blot/rub while the cleaner is still wet. It evaporates quickly. Wear gloves and, follow instructions. Re: How to remove spray paint from floor 8Apr 20, 2017 11:35 pm Mineral spirits or a stain remover is the best option to remove extra paint. I have used mineral spirit in past. Within 5 minutes all paint spots were gone. Yes you can go for it...It’s time to exercise How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5900 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11829 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7063 |
