Browse Forums Landscape & Garden Design Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 30Jan 15, 2017 7:28 pm Oh you're a good plant mum! My bromeliads are burnt as anything :/ I'm taking them all out of the garden tomorrow and putting them... somewhere. Not sure where yet! Maybe under a bed sheet too Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 31Jan 25, 2017 9:03 pm This is the actual space between main house and outdoor living area. 6 meters
Upon seeing the actual distance.... I will have to redesign the garden for this area. Currently I have 3 meters of timber deck joining to the main house.... which leaves around 3 meters of garden patch. I do wants to create more privacy between the out door living area and alfresco. I may have to utilise the whole space 6 meters by 5.5 meters... cover up with plants. Hubby also mention he wants fish pond to be located underneath a foot path. So back to drawing board and more research. Building thread : viewtopic.php?f=31&t=81624 Landscape thread : viewtopic.php?f=19&t=86133 Timing on page 1 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 33Jan 27, 2017 8:05 pm Were you going to use the 3m of deck for furniture? If you dont need to then you'd get the same look with only say 1.2 or 1.5m wide of deck. Or 900mm even will give you a splash of warm timber between the garden and your patio. That said plants filling the whole space will look terrific as well Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 34Jan 27, 2017 9:19 pm cat_dunc Were you going to use the 3m of deck for furniture? If you dont need to then you'd get the same look with only say 1.2 or 1.5m wide of deck. Or 900mm even will give you a splash of warm timber between the garden and your patio. That said plants filling the whole space will look terrific as well The reason we plan to have deck is ... to be able to access into the garden from the lounge room. As there is around 50cm - 70 cm drop from the sliding door to the garden outside. So we need to have decking to step out. otherwise we have to use kitchen's sliding door just to access into garden. But after seeing the actual distance from alfresco to out door living...and by adding 3 meters deck... I feel main house area is encroaching into the outdoor living area. I feel out door living area needs its own space. The empty space in between must show element of strong structure...such as a large tree, large fish pond...a statement room claiming this is my space. So I think has to be green patch of garden from alfresco area to out door living area. I will still need to have small decking to step out from lounge room. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ In the original plan to have two sun lounge on the deck. I can always put these on the lawn. Building Thread : viewtopic.php?f=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Timing on page 1 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 35Jan 27, 2017 10:55 pm Ok I have 2 new plans , any thought?
New design 1 - Taken out all decking from lounge room to alfresco - Move path to side of out door living - Large tree to divide alfresco and out door living - Deck outside of lounge 1.5 meters Build Thread : viewtopic.php?f=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Timing on page 1 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 36Jan 27, 2017 10:56 pm Design 2
- taken out decking from lounge to alfresco - location of path from alfresco to out door living same as original plan but now longer - deck outside of lounge 1.5 meters - steps for deck longer - large tree to divide alfresco and out door living area. - any advice? I think design 1 will give more ground space Build Thread : viewtopic.php?f=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 37Jan 28, 2017 9:38 am I vote 1! Would you consider continuing the deck along in front of alfresco just to in line with the path, then you step down from the deck onto the path? You might find it handy walking from alfresco to lounge door via the deck without needing to step on the pavers or garden? Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 39Mar 29, 2017 8:31 am I like this for the space between alfresco and outdoor living. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Build Thread : viewtopic.php?=31&t=81624 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 40Mar 29, 2017 8:37 am This one is nice but too much work for up keeping ( another word ...I don't like hedging ) Don't have to have same plants, I can still apply same look with different plants...... colourful croton plants for inner ring ( will create fire effects) and philodendron xanadu for outer ring. As for croton plants simple cutting regularly will keep shape and xanadu never need any trim apart from pulling out yellowish leafs. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Build Thread : viewtopic.php?=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Landscape Design Parramatta We have been doing a large amount of landscape design work in Sydney… 0 3 Hi All, Recently we have signed a contract with Burbank and we are not aware that they have just DORSET, SURREY, HAMPSHIRE, KENT, PILBARA and REDGUM bricks from PGH are… 0 3357 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37826 |
