Browse Forums Building A New House Re: Metricon Liberty 45 in Ryde NSW 201Jan 10, 2017 9:08 pm Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 203Jan 10, 2017 10:57 pm Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 207Jan 11, 2017 9:57 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: Metricon Liberty 45 in Ryde NSW 208Jan 12, 2017 8:53 am Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 209Jan 12, 2017 10:42 am Rules in NSW are so strict! Here in QLD any retaining wall under 1m in height requires no certification. Re: Metricon Liberty 45 in Ryde NSW 210Jan 13, 2017 6:08 pm Quirmeball1280 Renman Orpheus [quote="Quirmeball1280"]So the latest update is that we went ahead with that retaining wall builder and they were all set up ready to go this week. Then we get a call from Council (probably because of our neighbour) and we're told that although Council has approved the retaining wall as per the DA approval, the construction certificate issued by the private certifier only covers the dwelling and not the retaining walls. We were told that we needed a separate construction certificate for the retaining wall Why M wouldn't apply for a construction certificate that covers something as essential as the retaining walls (that they had drawn in in the Council stamped plans) is beyond me. Probably M thought that because they are only responsible for building the house, the other bits didn't matter. So our lesson learnt is that we have to check closely what is covered and not covered by the construction certificate as the construction certificate may have a narrower scope than the DA approval Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Yeah M has it in the council drawings which mentions owner is responsible for the retaining wall. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 This is a good point. As we have a long retaining wall on the side of the house that M will built. Will check with them on the certificate. Hi Renman, it will also depend on how the wall is drawn into the plans as part of the house plans submitted for approval. If the wall meets the requirements that exempt approval, you won't need to get a construction certificate for the wall. For example, had our wall been less than 600mm high and more than 1m away from the boundary, we probably wouldn't need a construction certificate. But our landscape plan (which was submitted and approved by Council as part of the DA approval) indicated that we wanted to build as close to the boundary as possible, eg 500mm from the boundary, to maximise the space to the side of the house. That's why we were then told we needed a separate construction certificate Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846[/quote] This is our boundary fence that is in question. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Metricon Liberty 45 in Ryde NSW 211Jan 13, 2017 7:33 pm It's similar to ours in that it's close to the boundary. It looks like your one might be over a metre. Hopefully your neighbours don't have as much free time as ours Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 212Jan 13, 2017 11:28 pm Quirmeball1280 It's similar to ours in that it's close to the boundary. It looks like your one might be over a metre. Hopefully your neighbours don't have as much free time as ours Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 They also build close to the boundary and because we have to cut the land we now have to under pinned the ground. Costing us an extra $11K. Metricon Liberty 45 in Ryde NSW 213Jan 14, 2017 8:36 pm Hi all, for those who are at the demolition stage, we thought we would share some reflections on picking the right demolition company. Our demo people were ok and we picked them cause they were cheaper than the other quotes we got. However, when M did the cut, they said that there was a lot of debris left in the soil so would charge us more to take the soil away. We ended up having to get someone else to take it away. In hindsight, it's best to make sure that the demo people take everything away. If there is still any debris, eg small pipes and bits and pieces (no matter how small) from the old house in the soil, it will give M an opportunity to charge more cause they will say the soil is 'contaminated' so the tip will charge more unless they get it filtered before taking it away Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And for some reason M decided to pour all the soil from the cut on our green bin instead of moving our bin to the side first Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 214Jan 14, 2017 9:05 pm Quirmeball1280 Hi all, for those who are at the demolition stage, we thought we would share some reflections on picking the right demolition company. Our demo people were ok and we picked them cause they were cheaper than the other quotes we got. However, when M did the cut, they said that there was a lot of debris left in the soil so would charge us more to take the soil away. We ended up having to get someone else to take it away. In hindsight, it's best to make sure that the demo people take everything away. If there is still any debris, eg small pipes and bits and pieces (no matter how small) from the old house in the soil, it will give M an opportunity to charge more cause they will say the soil is 'contaminated' so the tip will charge more unless they get it filtered before taking it away Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And for some reason M decided to pour all the soil from the cut on our green bin instead of moving our bin to the side first Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 That's is terrible to have gone through that by both demolisher and then with M. We have been told that our demolisher is really good and also happens to be the cheapest so far. Speaking our landscaper, the demolisher takes the useful rubble (i.e. Bricks) and sell them for extra $$$ on top of the fee. Re: Metricon Liberty 45 in Ryde NSW 215Feb 02, 2017 10:29 am nomnomnom Is there anyway you can say the retaining wall forms part of the landscaping works which are covered by the landscape drawings. And therefore covered by the construction certificate and the final occupation certificate? Really sorry to hear this. It's awful that this has happened. Terribly frustrating I would imagine. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Quirmeball1280 So the latest update is that we went ahead with that retaining wall builder and they were all set up ready to go this week. Then we get a call from Council (probably because of our neighbour) and we're told that although Council has approved the retaining wall as per the DA approval, the construction certificate issued by the private certifier only covers the dwelling and not the retaining walls. We were told that we needed a separate construction certificate for the retaining wall Why M wouldn't apply for a construction certificate that covers something as essential as the retaining walls (that they had drawn in in the Council stamped plans) is beyond me. Probably M thought that because they are only responsible for building the house, the other bits didn't matter. So our lesson learnt is that we have to check closely what is covered and not covered by the construction certificate as the construction certificate may have a narrower scope than the DA approval Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Q1280 how did you get on with the retaining walls certificate? Like the idea from Nom. I'm just starting to get landscapers engaged as our build is progressing and it's worth (from what I read) to get them lined up early. Ive asked M the same question about retaining wall permission as they did call this out back in July as we moved into construction. Landscapers have both said that it should have been covered by DA. Build thread - viewtopic.php?f=31&t=78995 Metricon Liberty 45 in Ryde NSW 216Feb 02, 2017 10:41 am NRyde Glendale37+ Q1280 how did you get on with the retaining walls certificate? Like the idea from Nom. I'm just starting to get landscapers engaged as our build is progressing and it's worth (from what I read) to get them lined up early. Ive asked M the same question about retaining wall permission as they did call this out back in July as we moved into construction. Landscapers have both said that it should have been covered by DA. Hi NRG, we were told by Council that it is covered by the DA approval. As Nom pointed out, it was clearly stated in our landscape plans. The bizarre issue is that the private certifier claims that the initial construction certificate issued only covers the dwelling build and not the retaining wall. So we had to get a new construction certificate which took 2 weeks. I still don't understand how a construction certificate can partially cover a DA approval but I wasn't going to argue since they are the PCA for my house build and I need them on my side What made it more difficult to get the extra construction certificate was that the certifier needed a licensed builder to take primary responsibility for the works and the guys I'm using are subcontractors (cementers, brickies) but they don't have a builders licence. So I then had to do the course and apply for an owner builder licence for the retaining wall works.. Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Metricon Liberty 45 in Ryde NSW 217Feb 02, 2017 11:59 am Quirmeball1280 NRyde Glendale37+ Q1280 how did you get on with the retaining walls certificate? Like the idea from Nom. I'm just starting to get landscapers engaged as our build is progressing and it's worth (from what I read) to get them lined up early. Ive asked M the same question about retaining wall permission as they did call this out back in July as we moved into construction. Landscapers have both said that it should have been covered by DA. Hi NRG, we were told by Council that it is covered by the DA approval. As Nom pointed out, it was clearly stated in our landscape plans. The bizarre issue is that the private certifier claims that the initial construction certificate issued only covers the dwelling build and not the retaining wall. So we had to get a new construction certificate which took 2 weeks. I still don't understand how a construction certificate can partially cover a DA approval but I wasn't going to argue since they are the PCA for my house build and I need them on my side What made it more difficult to get the extra construction certificate was that the certifier needed a licensed builder to take primary responsibility for the works and the guys I'm using are subcontractors (cementers, brickies) but they don't have a builders licence. So I then had to do the course and apply for an owner builder licence for the retaining wall works.. Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Wow that sounds like fun. Could you share details of the course? Will be checking with landscapers if they have the required licence as they'll be doing the driveway as well. I'm assuming you got details from M of the certifier? Build thread - viewtopic.php?f=31&t=78995 Re: Metricon Liberty 45 in Ryde NSW 218Feb 02, 2017 12:12 pm NRyde Glendale37+ Quirmeball1280 NRyde Glendale37+ Q1280 how did you get on with the retaining walls certificate? Like the idea from Nom. I'm just starting to get landscapers engaged as our build is progressing and it's worth (from what I read) to get them lined up early. Ive asked M the same question about retaining wall permission as they did call this out back in July as we moved into construction. Landscapers have both said that it should have been covered by DA. Hi NRG, we were told by Council that it is covered by the DA approval. As Nom pointed out, it was clearly stated in our landscape plans. The bizarre issue is that the private certifier claims that the initial construction certificate issued only covers the dwelling build and not the retaining wall. So we had to get a new construction certificate which took 2 weeks. I still don't understand how a construction certificate can partially cover a DA approval but I wasn't going to argue since they are the PCA for my house build and I need them on my side What made it more difficult to get the extra construction certificate was that the certifier needed a licensed builder to take primary responsibility for the works and the guys I'm using are subcontractors (cementers, brickies) but they don't have a builders licence. So I then had to do the course and apply for an owner builder licence for the retaining wall works.. Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Wow that sounds like fun. Could you share details of the course? Will be checking with landscapers if they have the required licence as they'll be doing the driveway as well. I'm assuming you got details from M of the certifier? No probs NRG, will PM you the details. Generally, most landscaping or retaining wall works won't require a building licence. As long as what you are doing is Council exempt, you won't need a building licence (although the contractors should be licensed and insured to do what they do). If what you do requires DA approval and a construction certificate, the certifier would then require you or the contractor to have a building licence. In our case, we needed a building licence because our retaining wall didn't meet the Council exempt requirements so we had to rely on the DA approval, and hence the construction certificate. Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 219Feb 02, 2017 12:21 pm Quirmeball1280 NRyde Glendale37+ Quirmeball1280 [quote="NRyde Glendale37+"] Q1280 how did you get on with the retaining walls certificate? Like the idea from Nom. I'm just starting to get landscapers engaged as our build is progressing and it's worth (from what I read) to get them lined up early. Ive asked M the same question about retaining wall permission as they did call this out back in July as we moved into construction. Landscapers have both said that it should have been covered by DA. Hi NRG, we were told by Council that it is covered by the DA approval. As Nom pointed out, it was clearly stated in our landscape plans. The bizarre issue is that the private certifier claims that the initial construction certificate issued only covers the dwelling build and not the retaining wall. So we had to get a new construction certificate which took 2 weeks. I still don't understand how a construction certificate can partially cover a DA approval but I wasn't going to argue since they are the PCA for my house build and I need them on my side What made it more difficult to get the extra construction certificate was that the certifier needed a licensed builder to take primary responsibility for the works and the guys I'm using are subcontractors (cementers, brickies) but they don't have a builders licence. So I then had to do the course and apply for an owner builder licence for the retaining wall works.. Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Wow that sounds like fun. Could you share details of the course? Will be checking with landscapers if they have the required licence as they'll be doing the driveway as well. I'm assuming you got details from M of the certifier? No probs NRG, will PM you the details. Generally, most landscaping or retaining wall works won't require a building licence. As long as what you are doing is Council exempt, you won't need a building licence (although the contractors should be licensed and insured to do what they do). If what you do requires DA approval and a construction certificate, the certifier would then require you or the contractor to have a building licence. In our case, we needed a building licence because our retaining wall didn't meet the Council exempt requirements so we had to rely on the DA approval, and hence the construction certificate. Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846[/quote] Who/how did you confirm if the wall was except from needing approval and a certifier? Was this from M, certifier or council? Build thread - viewtopic.php?f=31&t=78995 Re: Metricon Liberty 45 in Ryde NSW 220Feb 02, 2017 12:39 pm There are some fact sheets on the Ryde Council website that summarise what activities don't require DA approval. There is a specific fact sheet for retaining walls. You can also call Council and ask - they are usually quite helpful. Our retaining wall didn't meet the Council exempt requirements because it was higher than 60cm and we want to build it closer that 1m from the boundary as we wanted to maximise the space we have on the side of our house. Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW 3 6412 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10751 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8204 |
