Browse Forums Building A New House Re: KDR Metricon Liberty - Hampshire 45 QLD 345Jan 11, 2017 9:37 pm Renman Orpheus Renman [quote="Orpheus"]My kitchen feature window is 686mm height. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 So what is the clearance from the bench to the bottom of the cabinets? Ours is the standard window and we have a clearance of 660mm. This was the reason we had to pick the Qasair Eastmore model for our induction. Our overhead cupboards are 730mm above the bench. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Just double checked out PC and we have the bigger 07-27 windows but our elevation drawing shows us it's only 660mm. Is it correct there I should be getting 730mm clearance like Orph and my elevation in the PC is wrong. I should wait for the final contract? If so, why does M do this and complicate thing when we have to nominate which range hood and cook top to install now. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [/quote] I forgot to mention we asked our SM to raise the overhead cabinets so it sits flush with the window frame (instead of the glass which would mean the height is around 680mm). Note also our plans says our window is 07-36(assume measurement includes frames) but contract description has it only as 686 x 3610 (I assume this is the glass measurements without the frame) @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: KDR Metricon Liberty - Hampshire 45 QLD 346Jan 11, 2017 9:43 pm Orpheus Renman Orpheus [quote="Renman"][quote="Orpheus"]My kitchen feature window is 686mm height. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 So what is the clearance from the bench to the bottom of the cabinets? Ours is the standard window and we have a clearance of 660mm. This was the reason we had to pick the Qasair Eastmore model for our induction. Our overhead cupboards are 730mm above the bench. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Just double checked out PC and we have the bigger 07-27 windows but our elevation drawing shows us it's only 660mm. Is it correct there I should be getting 730mm clearance like Orph and my elevation in the PC is wrong. I should wait for the final contract? If so, why does M do this and complicate thing when we have to nominate which range hood and cook top to install now. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [/quote] I forgot to mention we asked our SM to raise the overhead cabinets so it sits flush with the window frame (instead of the glass which would mean the height is around 680mm). Note also our plans says our window is 07-36(assume measurement includes frames) but contract description has it only as 686 x 3610 (I assume this is the glass measurements without the frame) @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] Would have thought that the cabinets would be flush with the windows, otherwise there will be a small plaster wall between the both of them. Re: KDR Metricon Liberty - Hampshire 45 QLD 347Jan 11, 2017 9:44 pm Renman Orpheus Renman [quote="Orpheus"][quote="Renman"][quote="Orpheus"]My kitchen feature window is 686mm height. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 So what is the clearance from the bench to the bottom of the cabinets? Ours is the standard window and we have a clearance of 660mm. This was the reason we had to pick the Qasair Eastmore model for our induction. Our overhead cupboards are 730mm above the bench. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Just double checked out PC and we have the bigger 07-27 windows but our elevation drawing shows us it's only 660mm. Is it correct there I should be getting 730mm clearance like Orph and my elevation in the PC is wrong. I should wait for the final contract? If so, why does M do this and complicate thing when we have to nominate which range hood and cook top to install now. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [/quote] I forgot to mention we asked our SM to raise the overhead cabinets so it sits flush with the window frame (instead of the glass which would mean the height is around 680mm). Note also our plans says our window is 07-36(assume measurement includes frames) but contract description has it only as 686 x 3610 (I assume this is the glass measurements without the frame) @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] Would have thought that the cabinets would be flush with the windows, otherwise there will be a small plaster wall between the both of them. [/quote] Nope, standard M design is to sit flush with the glass unless you ask them to change it. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: KDR Metricon Liberty - Hampshire 45 QLD 348Jan 11, 2017 9:45 pm Renman Orpheus Renman [quote="Orpheus"][quote="Renman"][quote="Orpheus"]My kitchen feature window is 686mm height. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 So what is the clearance from the bench to the bottom of the cabinets? Ours is the standard window and we have a clearance of 660mm. This was the reason we had to pick the Qasair Eastmore model for our induction. Our overhead cupboards are 730mm above the bench. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Just double checked out PC and we have the bigger 07-27 windows but our elevation drawing shows us it's only 660mm. Is it correct there I should be getting 730mm clearance like Orph and my elevation in the PC is wrong. I should wait for the final contract? If so, why does M do this and complicate thing when we have to nominate which range hood and cook top to install now. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [/quote] I forgot to mention we asked our SM to raise the overhead cabinets so it sits flush with the window frame (instead of the glass which would mean the height is around 680mm). Note also our plans says our window is 07-36(assume measurement includes frames) but contract description has it only as 686 x 3610 (I assume this is the glass measurements without the frame) @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] Would have thought that the cabinets would be flush with the windows, otherwise there will be a small plaster wall between the both of them. [/quote] Nope, standard M design is to sit flush with the glass unless you ask them to change it. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: KDR Metricon Liberty - Hampshire 45 QLD 349Jan 11, 2017 9:51 pm Orpheus Renman Orpheus [quote="Renman"][quote="Orpheus"][quote="Renman"][quote="Orpheus"]My kitchen feature window is 686mm height. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 So what is the clearance from the bench to the bottom of the cabinets? Ours is the standard window and we have a clearance of 660mm. This was the reason we had to pick the Qasair Eastmore model for our induction. Our overhead cupboards are 730mm above the bench. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Just double checked out PC and we have the bigger 07-27 windows but our elevation drawing shows us it's only 660mm. Is it correct there I should be getting 730mm clearance like Orph and my elevation in the PC is wrong. I should wait for the final contract? If so, why does M do this and complicate thing when we have to nominate which range hood and cook top to install now. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [/quote] I forgot to mention we asked our SM to raise the overhead cabinets so it sits flush with the window frame (instead of the glass which would mean the height is around 680mm). Note also our plans says our window is 07-36(assume measurement includes frames) but contract description has it only as 686 x 3610 (I assume this is the glass measurements without the frame) @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] Would have thought that the cabinets would be flush with the windows, otherwise there will be a small plaster wall between the both of them. [/quote] Nope, standard M design is to sit flush with the glass unless you ask them to change it. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] I recall a bit of a discussion (in the Building with Metricon? thread) about this when it was discovered that quite a few of those building with Metricon had overhang of their kitchen cabinetry into the splashback window. Re: KDR Metricon Liberty - Hampshire 45 QLD 350Jan 11, 2017 9:53 pm anonymous- Orpheus Renman [quote="Orpheus"][quote="Renman"][quote="Orpheus"][quote="Renman"][quote="Orpheus"]My kitchen feature window is 686mm height. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 So what is the clearance from the bench to the bottom of the cabinets? Ours is the standard window and we have a clearance of 660mm. This was the reason we had to pick the Qasair Eastmore model for our induction. Our overhead cupboards are 730mm above the bench. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Just double checked out PC and we have the bigger 07-27 windows but our elevation drawing shows us it's only 660mm. Is it correct there I should be getting 730mm clearance like Orph and my elevation in the PC is wrong. I should wait for the final contract? If so, why does M do this and complicate thing when we have to nominate which range hood and cook top to install now. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [/quote] I forgot to mention we asked our SM to raise the overhead cabinets so it sits flush with the window frame (instead of the glass which would mean the height is around 680mm). Note also our plans says our window is 07-36(assume measurement includes frames) but contract description has it only as 686 x 3610 (I assume this is the glass measurements without the frame) @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] Would have thought that the cabinets would be flush with the windows, otherwise there will be a small plaster wall between the both of them. [/quote] Nope, standard M design is to sit flush with the glass unless you ask them to change it. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] I recall a bit of a discussion (in the Building with Metricon? thread) about this when it was discovered that quite a few of those building with Metricon had overhang of their kitchen cabinetry into the splashback window.[/quote] Yup that was me who started the discussion.... @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: KDR Metricon Liberty - Hampshire 45 QLD 352Jan 12, 2017 10:35 am Re: KDR Metricon Liberty - Hampshire 45 QLD 353Jan 12, 2017 10:38 am Nice, looks like yr overhead cupboards sit flush with the window frame. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: KDR Metricon Liberty - Hampshire 45 QLD 354Jan 12, 2017 10:49 am Plus Renman has nothing to worry about, with 3m high ceilings you have lots of room to play with. Overhead cupboards can be placed at what ever height you like. I think it only becomes an issues with people with low ceilings and limited space. Re: KDR Metricon Liberty - Hampshire 45 QLD 355Jan 12, 2017 1:19 pm Re: KDR Metricon Liberty - Hampshire 45 QLD 356Jan 12, 2017 1:21 pm Wow I would love 3m or even 4m ceilings if it was offered. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: KDR Metricon Liberty - Hampshire 45 QLD 357Jan 12, 2017 1:25 pm I don't think they offer 3m ceilings for non signature range homes but I guess if you insist and are willing to pay for it then they'll come to the party. Last time someone told me it was some ridiculous amount being 45K but Renman can correct me on this. i.e. 3m downstairs and 2.7m upstairs. Re: KDR Metricon Liberty - Hampshire 45 QLD 358Jan 12, 2017 1:28 pm vuster I don't think they offer 3m ceilings for non signature range homes but I guess if you insist and are willing to pay for it then they'll come to the party. Last time someone told me it was some ridiculous amount being 45K but Renman can correct me on this. i.e. 3m downstairs and 2.7m upstairs. That price does sound ridiculous. I rather use that money to buy a new Mercedes and park it in the garage. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: KDR Metricon Liberty - Hampshire 45 QLD 360Jan 12, 2017 9:02 pm Todays progress - Windows! Guest Ensuite Window Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Pantry and Kitchen Picture Windows. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 1 of 4 Boutique Stacker Door Frame. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Upstairs Lounge Room Window. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bed 2 Windows. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bed 3 Window. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bed 4 Window Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master Ensuite Toilet and Bath Windows. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master Windows Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master WIR Windows. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Picture Window for the stair well. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Looking in from the street. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37197 The biggest challenge will be if you take out a loan and then run out of money - you'll have an incomplete security and lenders do not like this so you can get stuck.… 2 19140 Hi, I am looking into doing a KDR in Melbourne and am contemplating using Kialla Homes. I am looking for feedback on them from others who have built with them. 0 13471 |
