Browse Forums Owner Builder Forum Re: OB Project - "New vs Old" - Nedlands, WA 466Dec 08, 2016 1:28 pm Build thread http://tinyurl.com/llgc7yk Re: OB Project - "New vs Old" - Nedlands, WA 468Dec 09, 2016 8:54 am What lucky kiddies to have that magnificent bathroom!! Love the sky light. I'm thinking of doing something similar. Our bathroom is just so dark. Do you think it would be hard to retro fit? C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: OB Project - "New vs Old" - Nedlands, WA 469Dec 09, 2016 11:50 am MrsJM What lucky kiddies to have that magnificent bathroom!! Love the sky light. I'm thinking of doing something similar. Our bathroom is just so dark. Do you think it would be hard to retro fit? C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 In my opinion skylights are worth their weight in gold. I placed one over each of our showers and they flood the area with natural light. We knew we were going to pick dark grey tiles so it was a must for us. Definitely able to be done later but much easier during build. To give an an idea that small one over the shower is a double glazed velux unit cost us about $300 plus install which was easy. The roofing guys then just flashed/water proofed it. Re: OB Project - "New vs Old" - Nedlands, WA 470Dec 15, 2016 5:41 pm Back to hard yakka....... My brick layer and I started to work one the front fencing. Got the worst bit of it out of the way - pouring the foundation. I always dread working with concrete. It's both exhausting and stressful. Good news is it all went relatively to plan. Not pretty though. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here is the plan I drew up for my bricklayer. The brickwork will be in long narrow charcoal bricks with a charcoal mortar. There will also be features of cement dado plaster. I've tried to make it look a bit different to the typical front pier fence. It will be finished off the steel slats. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ OB Project - "New vs Old" - Nedlands, WA 472Dec 23, 2016 9:18 pm Some more progress with the painting all the windows, doors and trims have been painted in Dulux lexicon 1/4 in satin finish. The front door has had its under coat in Dulux duck egg blue. It looks exactly as I wanted. Can't wait for the topcoat. Next will be painting the Ballustrade in charcoal micaceous paint. Happy Christmas to everyone!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: OB Project - "New vs Old" - Nedlands, WA 474Dec 23, 2016 11:32 pm hrvat_ica The colours just go so well together, you must be soo happy how the new and the old has come together I must thank you for the front door colour. As soon as they started painting it I knew it was going to work perfectly. Yes it makes for a pretty interesting entrance as you can't see the addition from the street. Re: OB Project - "New vs Old" - Nedlands, WA 475Dec 24, 2016 1:06 pm Original internal doors were in crappy condition and all had warped so they were replaced with solid timber doors. Shame to paint them really. The Art Deco door hardware is all original but the brass has been acid aged to tone down the shine. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ OB Project - "New vs Old" - Nedlands, WA 476Dec 29, 2016 3:45 pm Attaching the bathroom fittings today. Again we have gone with the matt black and aged brass combination. All the gear is from either Rogerseller or Astra walker. Ensuite toilet: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Now we have roughly 20 different items to attach to the walls from towel hooks to toilet cleaners etc and I need to be able to drill approx 50 holes through the tough but brittle porcelain tiles. Last thing I want to do is crack or chip a tile. The best way I have found to go through these is by using diamond core drill bits. I've purchased about 20 from eBay for about $1 ea. They only last 2 or so holes and need constant cooling with water so it's a slow process. They achieve a perfect result though. One of my most hated things is loose or wobbly fittings. Drives me nuts. Cheap as chips: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Very tight fit: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Result: powder room toilet roll holder. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Now 40 more holes to go. Re: OB Project - "New vs Old" - Nedlands, WA 477Dec 29, 2016 8:25 pm Love your fixtures!!! Wished you built way ahead of me! I would of loved to copy your choices!!! Re: OB Project - "New vs Old" - Nedlands, WA 478Jan 22, 2017 7:33 pm Howdy everyone... it's been a while since my last update. We've been away on a short holiday and generally lazing around. Not much has happened with the house but I'm starting to get a move on with the front landscaping. Starting with walls, retic lines etc. I've also drawn up the carport with the intention of starting construction as soon as possible. The initial design was of bricks and tiles to blend in with the front 1930s bungalow but I have decided to industrialize it which will hint at what's at the rear of the house. I'll order the steel once I've poured the footings and hopefully build it myself. I've designed it such that construction should be very easy. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Also 2-3 months after moving in we have been delivered 4 of the 10 remaining steel doors. Really excited to start removing some of the plywood in our living room. Each door is 2.7m high by 910 wide. The wife and I have had a fun couple of nights painting them. Not. Plan is for them to be installed and glazed on Friday. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: OB Project - "New vs Old" - Nedlands, WA 479Jan 23, 2017 3:21 pm Far out those doors are sexy!! Can't wait to see them installed! C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 DIY, Home Maintenance & Repair That laser level looks lovely! We bought one for less than a quarter of that price off eBay. It worked really well for us and it's still going now, five years later. After… 1 16991 If you need to pay for a project manager you would be well advised to just engage a builder who would take full responsibility for the build. As opposed to you OB where… 5 15322 |
