Browse Forums Building Standards; Getting It Right! Re: Rendered EPS Pier on facade. 4Oct 10, 2016 9:20 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Rendered EPS Pier on facade. 5Oct 10, 2016 11:28 am @structuralBIMGuy thank you. I was just about to reply your message. I am in Parks Edge estate in Melbourne. I am not sure what material it is but i know they used the same thing around the corner window. If you see the first photo posted above. The board around the corner was in pink. They painted to grey. The skirting board on the bottom of the pier is pink too so i assume it is the same material The rendered pier size is 590 X590 MM. It has a is 90 x 90mm timber post inside. So i assume it the foam thingy in between ? The depth of the gap on the bottom is all the way to the timber post. If i used a stick , I can reach the timber post. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Rendered EPS Pier on facade. 6Oct 10, 2016 6:21 pm Hi Christina The EPS trim would probably finish the gap off a bit better than simply trying the fill it Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Rendered EPS Pier on facade. 7Oct 24, 2016 10:29 pm sunxiaoxuan23926 Emmz70 Can't say I've ever seen this before Sun Very odd indeed. Hope someone helps you Thanks Emma, I just came back from walk around Livingston and my estate . I can't see one house has timber or whatever board around. Sun my silly messages can't send. But I have read what you've sent!!! So angry!!!! Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 4193 I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12155 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7262 |
