Browse Forums Building A New House Re: Celebration Homes Build in Piara Waters WA [Slab] 41Mar 05, 2016 4:03 pm Mason Green Estate, Piara Waters with Celebration Homes: https://forum.homeone.com.au/viewtopic.php?t=79358 Re: Celebration Homes Build in Piara Waters WA [Slab] 43Mar 09, 2016 3:26 pm Mason Green Estate, Piara Waters with Celebration Homes: https://forum.homeone.com.au/viewtopic.php?t=79358 Re: Celebration Homes Build in Piara Waters WA [Slab] 44Mar 10, 2016 10:50 pm Mason Green Estate, Piara Waters with Celebration Homes: https://forum.homeone.com.au/viewtopic.php?t=79358 Re: Celebration Homes Build in Piara Waters WA [Slab] 45Mar 11, 2016 10:49 pm Mason Green Estate, Piara Waters with Celebration Homes: https://forum.homeone.com.au/viewtopic.php?t=79358 Re: Celebration Homes Build in Piara Waters WA [Bricks] 46Mar 12, 2016 10:11 pm More work done on the walls today! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The lighter brick at the bottom was done yesterday, so I assume it looks different like that because they washed that section (I hope). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Mason Green Estate, Piara Waters with Celebration Homes: https://forum.homeone.com.au/viewtopic.php?t=79358 Re: Celebration Homes Build in Piara Waters WA [Bricks] 47Mar 13, 2016 8:35 pm Hiya, posting to follow along, we are at a very similar stage and we both have Ocean Foam Casesarstone! The holes are weep holes. They are a course or two up so they don't get covered by any paving. I guess you probably know already they are to allow water to escape the brick work cavity should any get in Our Custom Dale Alcock build in the Village at Wellard https://forum.homeone.com.au/viewtopic.php?f=31&t=78620 Re: Celebration Homes Build in Piara Waters WA [Bricks] 48Mar 13, 2016 8:43 pm Wellard2ndTimers Hiya, posting to follow along, we are at a very similar stage and we both have Ocean Foam Casesarstone! The holes are weep holes. They are a course or two up so they don't get covered by any paving. I guess you probably know already they are to allow water to escape the brick work cavity should any get in I was actually just reading through your thread Your build is looking very good. Your bricks are a very similar colour to mine and I love them. I almost wish the front of my house won't be rendered so they would use the bricks instead. Yeah, I figured it out about the weep holes after some googling. Luckily I hadn't sent off a complaint about it to the builder yet Our bricks should be done by the end of the week with the roofing scheduled to start next Monday. Looking forward to also following your build. Celebrations and Dale Alcock are part of the same group so I expect they follow a very similar process. Mason Green Estate, Piara Waters with Celebration Homes: https://forum.homeone.com.au/viewtopic.php?t=79358 Re: Celebration Homes Build in Piara Waters WA [Bricks] 49Mar 14, 2016 12:54 am Just started following your thread. I like your design and colour selection... Wow brick work done is one week, that's very quick. At this rate you will have key handover in Jul/Aug.. Fantastic. We got pre-start booked with Celebration Homes in 2 weeks. So, going through selection process... seems like a never ending task. I think our elevation is similar to yours ... Is that based on Rio? Can you please let me know the external electrical contractors you used to do your electrical plan? We are thinking of doing the lighting, ceiling fans and powerpoints after the handover. Egerton Village, Vale with Celebration Homes - https://forum.homeone.com.au/viewtopic.php?t=81772 Re: Celebration Homes Build in Piara Waters WA [Bricks] 50Mar 14, 2016 1:15 am rjrj Just started following your thread. I like your design and colour selection... Wow brick work done is one week, that's very quick. At this rate you will have key handover in Jul/Aug.. Fantastic. We got pre-start booked with Celebration Homes in 2 weeks. So, going through selection process... seems like a never ending task. I think our elevation is similar to yours ... Is that based on Rio? Can you please let me know the external electrical contractors you used to do your electrical plan? We are thinking of doing the lighting, ceiling fans and powerpoints after the handover. Hey! Always good to see other Celebrations builders on here. I found pre-start pretty easy, but we didn't put too much thought into the colours. Luckily we found a display home of theirs that we liked the look of and stole those colours. Made things easier. I am not too sure which design my elevation is from. I don't see the Rio on their site any more to check. When we first met with Celebrations we were given a booklet with some of the 12.5m house designs and along the bottom it had a few examples of elevations. We liked the look of the one we have (the traditional elevation) and asked for it. I am a fan of gables. It does seem to be the exact same as yours. Is your design the Rio? My electrical plan I did myself in terms of the power points, but for the lighting I sent my floor plan to the guys at Lightcube Designs (http://www.lightcubedesigns.com.au) as they had done the lighting for a friend. They sent back a lighting plan which I then emulated onto my electrical plan. This helped a lot as I was really unsure of how many lights I would need and where to place them. For most rooms I just moved the existing light point to one of the locations on my lighting plan. The electrician can then replace it with a downlight and add the rest of them. The important thing is to have either a light point or a junction box for each set of lights that you want. Mason Green Estate, Piara Waters with Celebration Homes: https://forum.homeone.com.au/viewtopic.php?t=79358 Re: Celebration Homes Build in Piara Waters WA [Bricks] 51Mar 14, 2016 2:09 am Thanks ! I am on the same boat. Not sure how many lights I required. We are getting 10 downlights as part of their promo. So, I am thinking of replacing bayonet on the other rooms with the downlight after the handover. I especially like your idea of putting the builders light point at where you want your downlight that way I don't have to plaster the light point which they normally put it in the middle Yes, my elevation is called Rio. I think they have "Redford" home design based on the Rio elevation. Egerton Village, Vale with Celebration Homes - https://forum.homeone.com.au/viewtopic.php?t=81772 Re: Celebration Homes Build in Piara Waters WA [Bricks] 52Mar 14, 2016 10:37 pm rjrj Thanks ! I am on the same boat. Not sure how many lights I required. We are getting 10 downlights as part of their promo. So, I am thinking of replacing bayonet on the other rooms with the downlight after the handover. You got the entertainers package promo they had? Lucky. When I signed up I was just able to get raised ceilings and caesarstone benchtops, but it wasn't free, just discounted. The promos the last few months have been way better. Mason Green Estate, Piara Waters with Celebration Homes: https://forum.homeone.com.au/viewtopic.php?t=79358 Re: Celebration Homes Build in Piara Waters WA [Bricks] 53Mar 14, 2016 10:43 pm A few more wall photos from today. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Mason Green Estate, Piara Waters with Celebration Homes: https://forum.homeone.com.au/viewtopic.php?t=79358 Re: Celebration Homes Build in Piara Waters WA [Bricks] 54Mar 17, 2016 10:56 pm Brickwork seems to have been completed today! It took 6 days of work all up. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Mason Green Estate, Piara Waters with Celebration Homes: https://forum.homeone.com.au/viewtopic.php?t=79358 Re: Celebration Homes Build in Piara Waters WA [Roof Frame] 55Apr 01, 2016 2:48 pm Hi Oduen did you use a building inspection company to conduct staged inspections of your build? Re: Celebration Homes Build in Piara Waters WA [Roof Frame] 56Apr 01, 2016 9:44 pm loulou1411 Hi Oduen did you use a building inspection company to conduct staged inspections of your build? I haven't yet but I plan to have an inspection when the roof frame is complete. I am going to use Mark from Bestwest Building as I have seen him recommended many times on these forums. I will also bring an inspector along when it is time for PCI. Mason Green Estate, Piara Waters with Celebration Homes: https://forum.homeone.com.au/viewtopic.php?t=79358 Re: Celebration Homes Build in Piara Waters WA [Roof Frame] 57Apr 01, 2016 9:47 pm After a couple of weeks of nothing much happening the roof frame was started today. It should take 3 days to complete so hopefully it is done early next week. The electrician and plumber should be following right behind. The estate has really been taking off lately. Every other day there are a couple of new slabs down. It's exciting to see and track how others are progressing. Stages 3 and 4 look almost ready for titles so hopefully those aren't too far away. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Mason Green Estate, Piara Waters with Celebration Homes: https://forum.homeone.com.au/viewtopic.php?t=79358 Re: Celebration Homes Build in Piara Waters WA [Roof Frame] 58Apr 04, 2016 11:16 am oduen After a couple of weeks of nothing much happening the roof frame was started today. It should take 3 days to complete so hopefully it is done early next week. The electrician and plumber should be following right behind. The estate has really been taking off lately. Every other day there are a couple of new slabs down. It's exciting to see and track how others are progressing. Stages 3 and 4 look almost ready for titles so hopefully those aren't too far away. Went through yesterday quickly, think I have stalked out your place now haha.. looks the same as the photos in case you were planning a trip today, guess they don't work the weekend though.. If you don't mind next time we are there we might have a wonder through your place because we have signed with Celebrations now (yay) and gone for the 31c throughout like you have and would be keen to see it in practice. Pretty sure stage 3 and 4 will title at the same time, construction due to be finished by "mid April" and then title 4-6 weeks after that, so mid May, early June more likely. On my street at least still waiting on road to be completed but doesn't look too far off, the retaining walls to have their render grout whatever its called put in the gaps between the blocks, and light poles etc to be installed. Don't think it would be a struggle to get that done in 10 days but I am not a land developer so who knows haha. We got a clause in our build contract that site works will start 2 days after settlement so bring on titles! I guess I should start my own thread! Re: Celebration Homes Build in Piara Waters WA [Roof Frame] 59Apr 04, 2016 2:22 pm alexkrad Went through yesterday quickly, think I have stalked out your place now haha.. looks the same as the photos in case you were planning a trip today, guess they don't work the weekend though.. Mine should be pretty easy to spot at the moment. At least as of Saturday it was the only one in stage 2 with a roof started. I will probably check it out tonight as hopefully they are working on it today. alexkrad If you don't mind next time we are there we might have a wonder through your place because we have signed with Celebrations now (yay) and gone for the 31c throughout like you have and would be keen to see it in practice. Sure thing, not a problem. alexkrad Pretty sure stage 3 and 4 will title at the same time, construction due to be finished by "mid April" and then title 4-6 weeks after that, so mid May, early June more likely. On my street at least still waiting on road to be completed but doesn't look too far off, the retaining walls to have their render grout whatever its called put in the gaps between the blocks, and light poles etc to be installed. Don't think it would be a struggle to get that done in 10 days but I am not a land developer so who knows haha. It definitely looks pretty close. Hopefully no more than a couple of weeks of work. I think mine took around 8 weeks from when it was finished to actually get the titles from council, but that included the Christmas break. With Stage 1 I think it was 6 weeks. Mason Green Estate, Piara Waters with Celebration Homes: https://forum.homeone.com.au/viewtopic.php?t=79358 Re: Celebration Homes Build in Piara Waters WA [Roof Frame] 60Apr 04, 2016 8:29 pm Roof continued today. Looks like all that is left is the remaining fascia and hardiflex. Should be done tomorrow. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Mason Green Estate, Piara Waters with Celebration Homes: https://forum.homeone.com.au/viewtopic.php?t=79358 Joe, it depends on your certifier but we are noticing the ones we deal with are really cracking down. So i would recommend you follow your approved landscaping plans to… 4 11531 Hi Simeon, Thank you for laying it down for us. Makes sense. Appreciate it very much. Have a nice day. Cheers 2 9497 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 19601 |
