Browse Forums Eco Living Re: Passive Solar Design in Sydney 9Mar 01, 2016 10:51 am Where it becomes difficult is where you have a door such as a bifold leading out onto a balcony on the same wall as a window with a sill at standard 1000mm above floor level. Not so much of a problem where the stud height is 2400 and a usual eaves overhang of 450mm but for any higher and you start to see the door copping some heat in summer. You can vary the eaves width over the doors to stop that but that can lead to problems too unless you go for a shading mechanism. Stewie 0 5123 I looked into it a few years ago and my conclusion was to just build a carport that will support panels and get a system installed separately. The company I looked at had… 1 6632 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19740 |
