Browse Forums General Discussion Re: Quote for raising house and building underneath 163Jan 15, 2016 1:08 pm simnatped My first question is, do we need complete plans done now that include the build underneath, in order to raise? Or, are plans where underneath is all open good enough for now? If you are doing it in stages just submit plans that cover each stage. However the rub is you'll be stung for an additional application fee for each stage. simnatped I imagine where the stumps go will impact what layout you can have downstairs later on... simnatped Can you lay a slab without the build-in plans, or do you need to know where future plumbing etc. will be for the slab? simnatped Second question, I imagine the height you can raise to (I'm in south Brisbane, not sure if BCC allows heights of 8.5 or 9.5m where I am) is determined from the ground to the highest point of the roof. Is there a special instrument I can measure this so I know how much higher I can raise? Our house is on a slope. Its been 8.5M for many years. I doubt it is any higher now. There may be a tool, but you can easily measure it yourself - get in your attic and measure the ceiling to roof height. Then measure outside from ground to floor, and floor to ceiling. (make sue you add in thickness of the floors /ceiling. Add the measurements. At what point on the ground you can measure from is often defined in the town plan. I would pop in to BCC in person and have a chat with a town planner for 10 mins about all these things, and get him to give you references in the town plan or Qld Development Code where he gets his info form. Then double check it yourself online (most important, because you want to verify any info a public servant gives you). The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3470 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 5315 hey there! 😊 so, it’s kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 21308 |
