Browse Forums Building A New House Re: Opinions on roof needed please 4Sep 03, 2015 6:22 pm Thanks guys more for looks then anything else Re: Opinions on roof needed please 6Sep 04, 2015 9:02 am If you went night sky, I think you'd have to consider black window frames. Re: Opinions on roof needed please 7Sep 04, 2015 9:08 am On looks only with that colour brick I'd go the lighter, monument roof. But if you go the darker roof than I agree with one John to match the window frames. Build thread: viewtopic.php?f=38&t=75302 Re: Opinions on roof needed please 8Sep 04, 2015 11:50 am I should mention our window frames, fascia and garage are all monument and Gutters are night sky - I think if we change to monument we will have gutters as monument and fascia as night sky Re: Opinions on roof needed please 9Sep 05, 2015 12:20 am oneJohn Unless you're in a very cold climate, generally the heat gain from a roof costs you more in summer than it benefits in winter, so in that case Monument with a solar absorptance of 73% wins out over Night Sky at 96%. Yes.. Reason why we went for surfmist. I'd go monument for the same reason if it's between those two. Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 5350 Minimum overhang into gutter must be 50mm, turn down tool should not split the sheet. it seems wrong tool for the profile was used, the flashing cannot slope back. Rib… 2 2484 Most of the time, council will push you out to a private certifier as it ties up their limited resources. Where a builder has gone belly up, the certifier passes the file… 7 6279 |
