Browse Forums General Discussion Re: URBAN MYTHS .... ? 186May 27, 2015 7:49 am Crazyk Think of a waffle as a bowl of jelly with custard on the top...custard being your waffle slab. Shake the jelly he slab moves with it. Waffles are only poured on top of the soil and not keyed into the earth. The pipe work connecting to the sewer and water is another question, but that doesn't matter what slab you have. Sorry thread hijacked Old thread I know. This is a reason to spend a little extra on your pipes and use stormplastics products. Joints are expandable and some swivel. Re: URBAN MYTHS .... ? 187May 27, 2015 10:59 am ...and are compulsory on reactive soils as per AS2870. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: URBAN MYTHS .... ? 188May 27, 2015 11:01 am SaveH2O ...and are compulsory on reactive soils as per AS2870. I miss the myths ... so what are you saying SH2O ... Re: URBAN MYTHS .... ? 189May 27, 2015 11:22 am Just stating that what goody59 posted is compulsory on reactive soils as per the Australian Standard I referenced. If there is an urban myth in there, it would be that all houses that were required to be built to this Standard since the Standard was mandated were in fact built to the Standard. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: URBAN MYTHS .... ? 190May 27, 2015 11:26 am Yeah, I've never seen a waffle pad around and it's mostly all part or full reactive clay... Re: URBAN MYTHS .... ? 191May 29, 2015 6:07 pm Certain things always make my antennae stand up - so to speak - eg "trust me" ... . I've had real estate agents tell me the market is not flat - its just not rising. But recently Telstra doubled my download total - considerably. Is this to make me download more - or just a ruse. They told me it would mean I could download so many more movies. Are they suggesting I download from "those" sites we all hear about ... I feel its just they know from my records I won't download anymore than I do now - and they can give me 500gbs more and I won't use it. Are Telstra really giving me something - or is it just a myth ? Re: URBAN MYTHS .... ? 192May 29, 2015 7:14 pm Tel$tra rely on the law of averages, that being if you currently stick to less than say 50Gb on a 100Gb plan, you are highly unlikely to use much more if any if they gave you a 500Gb plan. It's all about making you feel warm and fuzzy about them. They know that they will get people that will use all of the extra given to them, but the vast majority won't use any more, and definately in the long term usage will pretty much remain the same. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: URBAN MYTHS .... ? 193Aug 07, 2015 3:27 pm A couple of ones that always amuse me... 1. Water drains down a basin clockwise in the southern hemisphere and anti clockwise in the northern hemisphere due to the Corolis effect. https://www.youtube.com/watch?v=4IIVfoDuVIw 2. An air bubble rises in water because air is lighter than water. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: URBAN MYTHS .... ? 194Aug 07, 2015 3:32 pm SaveH2O A couple of ones that always amuse me... 1. Water drains down a basin clockwise in the southern hemisphere and anti clockwise in the northern hemisphere due to the Corolis effect. https://www.youtube.com/watch?v=4IIVfoDuVIw 2. An air bubble rises in water because air is lighter than water. But you have overcome the issue of #2. Mighty cleverly too I might add. # 1 is interesting though. Re: URBAN MYTHS .... ? 195Aug 07, 2015 3:55 pm goody59 But you have overcome the issue of #2. Yes...in one application but that doesn't correctly explain why bubbles rise in water. I'm not explaining why the urban myth is wrong this early but it has nothing to do with air being lighter than water. Hmmm...just noticed that I spelt Coriolis with one i. Oops! 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: URBAN MYTHS .... ? 196Oct 07, 2015 1:46 pm I missed these - been away - but more grist for the mill. Re: URBAN MYTHS .... ? 197Dec 18, 2015 4:23 pm And back to my favourite subject. Has anyone heard that a slab poured in winter can be weaker than one poured in the warmer months. I can't seem to find out why - but was told it is true ! Apparently this person was told by and expert. Re: URBAN MYTHS .... ? 199Dec 18, 2015 8:48 pm I would assume that the concrete wouldn't be weaker but just take longer to reach full strength. This would of course need to be tempered with how cold you are talking about. If you are talking around 0º C then the water in the mix would possibly freeze and definitely cause problems. Mr Google comes up with this... http://www.holcim.com.au/editorials/con ... ather.html Stewie Re: URBAN MYTHS .... ? 200Dec 19, 2015 7:45 am One can only wonder about a waffle pod done in the depths of winter ... |
