Browse Forums Interior Decorating Lounge Re: Which colour roman blind (links included) 2Nov 21, 2008 10:06 am Maleena Hardy Curiouser & Curiouser Vintage-Handmade-Interior & Colour Consultancy http://www.curiouserandcuriouser.com.au Re: Which colour roman blind (links included) 4Nov 21, 2008 5:48 pm MaleenaH I like pearl and cashew, maybe vanilla. I would use a colour that is similar to your wall colour if you want it to blend in (hope that makes sense). Not good with words this morning. Judie I would try and get the blind as close to wall colour as possible. That way it doesn't become a feature and lets your table stand out. Judie This is my rule of thumb also…….by making the blind the wall colour, or as close as you can, you are extending the room from not cutting off with a different colour. Stacker and romans?????? Not sure if that’s you best choice in a blind for a door. Make sure it gets hung high over the door frame, or you will be ducking coming in and out of the doors. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Which colour roman blind (links included) 6Nov 22, 2008 12:05 pm Stacker and romans?????? Not sure if that’s you best choice in a blind for a door.
Make sure it gets hung high over the door frame, or you will be ducking coming in and out of the doors. [/quote] Just as Michelle said, make sure the roman blind get hung higher over the door frame, so when it is up it is just covering the door frame instead of hanging on the inside of it. Maleena Hardy Curiouser & Curiouser Vintage-Handmade-Interior & Colour Consultancy http://www.curiouserandcuriouser.com.au Re: Which colour roman blind (links included) 7Nov 22, 2008 12:10 pm Not going to give you anything constructive here.... ...I just had to say I'm so jealous that you have a Zuster table - I LOVE their stuff!!!!!! I want to come to your place and admire your table!!! Good luck with your blind choice Solidarity, not solidity.......The Lexicon of Life Re: Which colour roman blind (links included) 9Nov 23, 2008 11:45 am Thanks everyone I did speak to someone and $ curtains and blinds and she said that romans were quite popular with stackers but as Michelle said they make sure they are hung well above the door frame.
Petal - I love that table too but I could never afford their stuff. An interior desginer was selling it on Ebay as she was redecorating her house and it no longer suited so I got it for a bargain. hey there! 😊 so, it’s kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 21382 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 8182 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12812 |
