Browse Forums Safer Living Re: IP Camera and cloud recording 8Dec 11, 2014 7:13 pm alexf40 To be honest I'm not really sure what I'm doing, still can't get it working correctly I thought it'd be easier to connect to the cams externally if they were connected just to the switch, but for some reason I can't connect directly to the cameras at all. I'm pretty sure the latest NVR firmware supports virtual host but don't quote me. Quote: At the moment they are connected to the DVR and the cameras work through the web interface and the IVMS software. But I'd like to access the cameras externally and have no idea how. You'll need to port forward the ports. Quote: I want to add them to cammy.com on my phone but the port scan doesn't find them, and if I try and add them manually I still need to access the camera directly so I can add the ftp details. Why not use iVMS-4500 on a smart phone? Quote: Do you have any Hikvision equipment? Had 3 Hikvision cams up until recently but they're taken down due to the renovation happening at home. I have another 8 cams to add to them. Re: IP Camera and cloud recording 9Dec 11, 2014 7:17 pm alexf40 It'll be saved to the NVR which can record at full frame rate, but I want to have it stored off site too. Not so worried about the quality here, as it's just for worst case scenario if the NVR is stolen. You need to hide the NVR better What I planned into my renovation was a utility cupboard to house surveillance and security gear. Re: IP Camera and cloud recording 10Dec 12, 2014 3:11 pm Hi Bels, Yep the newer firmware is supposed to have virtual host settings, mine was running 3.0.8 and didn't have it, so upgraded to the latest version 3.0.10 and it doesn't have it either. I'll look into the port forwarding, thank you. I've got the iVMS-4500 ap but unless I'm doing something wrong it can't find the cameras. The DVR can find the cameras, but even the desktop SADP software doesn't find them either. I'm going to put the server cabinet on the wall in the garage, it'll be 3m high bolted through a brick wall so will be very awkward to get. I could run a cat6 up to a cupboard which will be almost exactly on top on the floor above. But think I prefer all the switch gear etc in one box. Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5992 which 1) PoE based video intercom is best for two storey home. I am looking with two monitor, one in GF and another FF so someone in home can… 0 25130 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10657 |
