Browse Forums Landscape & Garden Design Re: What's drilling holes in my lawn? 4Aug 18, 2013 5:15 pm Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: What's drilling holes in my lawn? 6Aug 19, 2013 11:45 am Jazzie Saint Mike I was going to say 'roos. They can dig a good hole - but not that deep - so not them. I'd love it if roos roamed the western suburbs of Melbourne thanks for your reply tho St Mike Well - when I lived in Canberra we had them. Now up here they're everywhere !!! It is nice to get up and see them on the golf course, ducks nearby, cranes and a multitude of other birds. And - emus - would you believe. But - no - sounds like you may have a grub problem. Re: What's drilling holes in my lawn? 7Aug 19, 2013 3:06 pm The holes are neat & round, about the width of a pencil with no sign of dirt mounds next to them You could just keep going when you poke a stick down them, they are like a long tube? I'll keep researching Thanks again for all your replies, really appreciate it. Jazz ps: would love to see roos or any wild life for that matter out my front door St Mike Life is like a lolly, suck it and see Re: What's drilling holes in my lawn? 8Sep 22, 2013 12:23 am Sounds like black beetle, pain in the bum. Get the appropriate chemical and water in well and will solve the problem. Had them some years ago and this solved the issue. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: What's drilling holes in my lawn? 9Sep 25, 2013 11:51 pm sounds more like a witchetty grub are the hole aroung say pinky finger sized? they are big wood/ root eaters live about 60cm+ in the ground Building the Montague 21 by Porter Davis at The Estuary, Leopold. Our Blog: http://porterdavismontague21.blogspot.com.au/ Re: What's drilling holes in my lawn? 10Oct 08, 2013 11:04 pm Hey Jazz, just to cancel everything out and depending on where you live, if they have only just appeared this spring then it is very possible they are cicada hole, they feed of the roots of the trees and then come up, this season has been immense with alot about. Pretty amazing as they come out of the ground after 17year almost exactly to the day that they went under ground. Good luck with your investigations. I use Tramex moisture meter and it will tell me instantly if the wall is cement sheet or plaster or masonite but most people dont have the equipment. 5 4582 it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 5033 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 4118 |
