Browse Forums Rental Property 1 Aug 28, 2016 7:47 pm Hey guys, next year I`ll build a new house in one of these new estates. It`s a 3x2x2, haven`t chosen the builder yet. I am planning to move in for the first year to get the grant from the government and rent it out straight after. Which upgrades do you reckon I should include to make sure it will be a bit different from all the others and will be rented out quickly? I have already included 900mm appliances, stone bench tops in the kitchen and bathroom. What about higher ceilings? Is it worth to spend +$4000 to move from 2550 to 2700? Anything else? Thanks Re: New House - What upgrade for renting quickly? 2Aug 28, 2016 7:55 pm Everything depends on your location but.. Important things for myself as a tenant are Ceiling fans aircondtioning Fenced yard. I don't think higher ceilings are worth it in the rental market. Re: New House - What upgrade for renting quickly? 3Aug 28, 2016 8:15 pm Fly screens and security screens. Re: New House - What upgrade for renting quickly? 4Aug 28, 2016 8:36 pm luca.321 Hey guys, next year I`ll build a new house in one of these new estates. It`s a 3x2x2, haven`t chosen the builder yet. I am planning to move in for the first year to get the grant from the government and rent it out straight after. Which upgrades do you reckon I should include to make sure it will be a bit different from all the others and will be rented out quickly? I have already included 900mm appliances, stone bench tops in the kitchen and bathroom. What about higher ceilings? Is it worth to spend +$4000 to move from 2550 to 2700? Anything else? Thanks I'd include the higher ceiling for future proof if you want to sell it doen the track, as it's not something you can just add after. Maybe also think if colorbond roof as they are usually low maintenance. Send from my phone. Pardon the incorrect autocorrect. Blog - http://sttropez27build.blogspot.com.au PM me for Boutique owners FB group Re: New House - What upgrade for renting quickly? 5Aug 28, 2016 8:45 pm This might be included already, but a dishwasher! As a tenant I personally wouldn't care about high ceilings (more expensive to heat) but would definitely want heating and cooling, preferably ducted but at least sufficient reverse cycle or gas wall furnace. I would also want reasonable internet so maybe making sure it's wired to support that would be a good? Re: New House - What upgrade for renting quickly? 6Aug 28, 2016 8:50 pm $4000 is a lot for upgraded ceiling... if your already at 2.5, probably don't need to go any higher especially for a rental. I'd focus on heating and cooling.. easy maintenance yard.. blinds.. LED lighting..more tangible things. Re: New House - What upgrade for renting quickly? 7Aug 28, 2016 9:57 pm As a property manager I'd say air con for all seasons (not sure which state you're in), security - screens or alarms, I'd say flyscreens are a basic need. High ceilings I wouldn't worry about. Dishwasher definitely. For your benefit I would make sure you have proper paint and not the crap that builders use. This won't form part of a wow factor for tenants however it is worth you paying extra for as it will mean less marks on walls down the line. Cheap watered down builders standard paint marks so easily and if you remove the marks that in itself leaves a mark. So proper washable paint is a massive bonus for you. Lastly, decent window coverings. Cheap plastic venetian blinds do not last long and bend and crease so they'll look crap after one tenant and are hard to clean. Blackout roller blinds last longer and are plasticised so much easier to clean. Re: New House - What upgrade for renting quickly? 8Aug 28, 2016 10:28 pm Hey guys, thanks for all your comments. I will include fly screens, dishwasher, ducted heating, cabling for internet, easy maintenance yard, blinds, LED lighting. Would you suggest air conditioning in all the rooms or just the living room? Re: New House - What upgrade for renting quickly? 9Aug 28, 2016 10:34 pm Air conditioning in living and main bed is good enough. My worst nightmare are those horrible venetian blinds. I much prefer curtains in a rental. As the are a lot cheaper to replace ( If you buy cheap ones in the first place) But that's totally personal preference. Re: New House - What upgrade for renting quickly? 10Aug 28, 2016 10:36 pm ZoePerth As a property manager I'd say air con for all seasons (not sure which state you're in), security - screens or alarms, I'd say flyscreens are a basic need. High ceilings I wouldn't worry about. Dishwasher definitely. For your benefit I would make sure you have proper paint and not the crap that builders use. This won't form part of a wow factor for tenants however it is worth you paying extra for as it will mean less marks on walls down the line. Cheap watered down builders standard paint marks so easily and if you remove the marks that in itself leaves a mark. So proper washable paint is a massive bonus for you. Lastly, decent window coverings. Cheap plastic venetian blinds do not last long and bend and crease so they'll look crap after one tenant and are hard to clean. Blackout roller blinds last longer and are plasticised so much easier to clean. A bit off topic but my hubby is a Painter and subcontracts for Builders in our area. He uses dulux wash and wear and exterior paint. You've picked the wrong builder if they are watering down cheap Paint. :/ Re: New House - What upgrade for renting quickly? 11Aug 28, 2016 10:46 pm Most new build properties that I have leased, and the one we lease now whilst we build, have the worst paint. Gives tenants a really hard time keeping walls clean, dramas at end of leases and shortens the time between full repaints for the owner to keep the property presentable and therefore ultimately easier to lease again. Not having a go at painters. I know builders screw subbies for the lowest rates Re: New House - What upgrade for renting quickly? 12Aug 29, 2016 12:04 am As a long time renter I look for a decent kitchen, dishwasher, gas cook top, air conditioning and central heating. Storage is also important to me. Idealing there'd be hearing and cooling in the bedrooms but not a deal breaker. Definitely would be a big plus tho. Customised Burbank Indigo/Hawthorn in Officer VIC https://forum.homeone.com.au/viewtopic.p ... 2#p1680752 Re: New House - What upgrade for renting quickly? 13Aug 29, 2016 11:37 pm When I use to rent I did not like ducted aircons, unless they're divided up into a reasonable amount of zones. The last house I rented had two zones - all four bedrooms and the other was for all living areas and the electricity bill was horrendous. When I wanted to cool just one bedroom - all 4 would be cooled. The other things I use to look for are lots of bench space in kitchens. It's so annoying trying to cook in a kitchen with minimal bench space. Appliances take up space. Now in my own home I have a 3.5 metre clear bench (Caesarstone) plus another 3x 1 metre spaces throughout the kitchen. And a big pantry - double door or walk I. My last rental had a single door pantry with a microwave shelf in between - too small. Other things - fans, security on all windows and doors. Side gates. And decent grass and gardens. Not weed ridden. Re: New House - What upgrade for renting quickly? 14Aug 30, 2016 12:11 am For the inside, think about the carpet choice and the fridge cavity because fridges come in a variety of shapes and sizes. Many tenants also require storage but there are also items that you don't want inside. I always made sure that my rentals had a generous size shed with double opening doors and some clear roof sheets (skylight). 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: New House - What upgrade for renting quickly? 15Jun 06, 2019 4:22 pm Air conditioner, ceiling fan, art room, washing machine, etc. I aspect as a tenant. Re: New House - What upgrade for renting quickly? 16Dec 05, 2019 11:07 pm I personally would upgrade to a 4x2x2 bedder if you can afford, if you can only get a 3x2x2 I would go 2700 ceilings and that will make the house look so much bigger. We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's… 0 14172 Good on you for having a go I am the opposite of DIY (so will pay a builder) - our vibe is industrial/simple so current thinking is 150mm concrete and then internally is… 3 1379 Yes well there solution is to blame everyone else while I a 65yr old woman with major medical problems have to just continue to boil water and wash myself in a bucket… 2 16215 |
