Browse Forums Lighting + Lighting Design 1 Sep 18, 2020 8:16 am Friends, Just moved into a house which requires sensor lights.in entrance, the block is 25m wide and has neighbour on either side. I am not sure what lights I would need and where ? I am considering the following 1. a single flood light above the garage and 2. a double light on the right corner of the house ? Added an image of the house , please advise . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Confused with sensor security lights 3Sep 18, 2020 9:43 am viju_009 Friends, Just moved into a house which requires sensor lights.in entrance, the block is 25m wide and has neighbour on either side. I am not sure what lights I would need and where ? I am considering the following 1. a single flood light above the garage and 2. a double light on the right corner of the house ? Added an image of the house , please advise . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Mr. Beams battery powered sensor lights? Buy say 4 of them and you can move them around until you get what you feel is ideal coverage. Powered by standard D cell batteries that last +6 months in service. Re: Confused with sensor security lights 4Sep 18, 2020 10:29 am arcadelt viju_009 ...please advise. Can you explain why you think you need sensor lights? There might be better options these days. Also, could you say what you budget is? We wanted few lights to glow up when some one is at the door or when there is movement in the entrance ? I am open to solar or even Battery operated lights as well. Also I want to minimise bringing in an electrician who use going to charge me a bomb for $50 light Re: Confused with sensor security lights 5Sep 19, 2020 1:44 pm viju_009 arcadelt viju_009 ...please advise. Can you explain why you think you need sensor lights? There might be better options these days. Also, could you say what you budget is? We wanted few lights to glow up when some one is at the door or when there is movement in the entrance ? I am open to solar or even Battery operated lights as well. Also I want to minimise bringing in an electrician who use going to charge me a bomb for $50 light https://www.amazon.com.au/Mr-Beams-MB390-300-Lumen-Weatherproof/dp/B00BCCNZA2/ref=asc_df_B00BCCNZA2/?tag=bingshopdesk-22&linkCode=df0&hvadid=&hvpos=&hvnetw=o&hvrand=&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=&hvtargid=pla-4583520391129186&psc=1 I'm curious, did they provide any reason why they did not like the idea? 1 15359 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8880 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 10476 |
