Browse Forums Lighting + Lighting Design 1 Nov 30, 2016 8:16 pm Hi
Doing a 2.1m high x 2.7m wide stack stone screen that will require RGB lighting to be "sprayed" up it, or across it from left to right the wall will be similar to this, except on each side will be part of a decked wall http://www.ledoutdoor.net.au/uploads/1/ ... 2_orig.png Trying to locate suitable options -Recessed / hidden look -RGB -Water Proof Option 1 - in ground, recessed linear RGB, something like https://www.alibaba.com/product-detail/ ... 15089.html Option 2 maybe these, running up the sides spraying across, say 5 each side of the stack stone wall http://www.ebay.com.au/itm/1-6-10-20-30 ... GFJEzUyNew Im thinking option 2 will give me the best coverage, and ability to aim the light, and cheaper hoping you can help, or provide other options thanks Re: Wall wash lighting for stack stone screen 3Jan 09, 2017 4:43 pm Option 1 is the winner. Select the 15 degree beam angle version. Buy two of them, position them end-to-end at the base of your stone wall, approximately 100-150mm out from the wall. Perhaps set up a night time mock-up so you can position them in your preferred spot. Option 2 will not produce a significant amount of light, they are basically toys. I wouldn't bother. Another important thing to note is that if your stack stone is a dark colour (grey, brown, black), then RGB colours will not show up particularly well at all, you will hardly see them. If the stone is a darker colour you may be better off with just a single colour warm white LED. It will create an interesting pattern of light from the uneven shadows caused from the stack stone. If your stack stone is a light colour (white, light grey, beige etc) then the colours will show up very well, it will be a real standout. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 5007 2 1252 I'm curious, did they provide any reason why they did not like the idea? 1 15135 |
