Browse Forums Lighting + Lighting Design 1 Feb 08, 2016 9:30 am Hi, In Melbourne we had a storm and we have some water dripping through the downlights. It has since stopped but am wondering since lights are still working and nothing seems different should we check it out. Should we get an electrician, plumber etc? Re: Water through downlight after storm 2Feb 08, 2016 7:15 pm At a minimum you'll want to find out why the water entered the roof space, so you can stop it happening again. Re: Water through downlight after storm 3Feb 08, 2016 10:07 pm Yep, I would either investigate myself or get a roof plumber out to find the source of the leak My build with FHBD viewtopic.php?f=31&t=78344 Re: Water through downlight after storm 4Feb 09, 2016 7:12 am Is this a new house ? If so I'd ring builder. But - I'd surely get it checked. Might just be a loose tile or some capillary action. Hi all, I have a lovely two story mid century house built 1962 with flat roof, box gutters and wide eaves. Unfortunately a tree came down on one corner and damaged a 4m x… 0 343 Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 8005 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6977 |
