Browse Forums Lighting + Lighting Design 1 Sep 21, 2015 2:41 pm I am hoping for some advice on my first rough draft of a lighting plan. I have not shown switches at this stage as I am just trying to work out the lights. I also have a Clipsec appointment to attend in the future but would like a good idea of what I need before I go. Apologies if it is hard to read. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi everyone I have a terracotta tiles roof When I climb inside the roof cavity I can feel that there is a draft inside the roof as the wind goes through the roof which is… 0 4975 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29437 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9345 |
