Browse Forums Lighting + Lighting Design 1 Jan 21, 2015 11:30 pm Hi everyone I'm looking at getting LED downlights installed after my house is finished building. Can anybody recommend some good places to go to in perth? So far I have been to one place and they are charging $50 per light to install when the light only costs $30! Not sure if this is reasonable? Re: LED Downlights Perth Recommendations? 2Feb 01, 2015 1:09 am MLEC want to charge me $85 per light ( include downlight). I don't know if they are good or not, but they did say if I install a lot there will be discounts. I haven't contact them back yet because I am still very far from installing down light. I will need around 42 downlights . Re: LED Downlights Perth Recommendations? 3Feb 01, 2015 8:59 am Hi powerrangers. $50 per light is a very good price. You consider if the light costs $30 the other 20 includes their labor charge to mark them out, cut the holes and crawl around in the roof to wire them all. If they are also including cable etc in that price then they can't be making very much. The standard price for supply and install of led downlights in vic is between $70-95 per light. Re: LED Downlights Perth Recommendations? 4Feb 08, 2015 6:48 pm It never ceases to amaze me how people complain about tradespeople pricing. People won't complain about spending $80 for a 5 minute consultation with a G.P. but will complain about a couple of hundred dollars for an electrician to drive half an hour across town to their house, spend half a day crawling around in a ceiling, using $100 worth of materials, then packing up, cleaning up, and drive across town to the next job. Trust me when I say that $80 to supply and install a light fitting is extremely good value. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: LED Downlights Perth Recommendations? 5Mar 05, 2015 8:30 pm i've been looking for a good place to buy LED lights from for my new house. lucky me that got suggested for CherryLEDand good thing is they have an online calculator where i could estimate the costing for whole setup and can also compare that for other lights. You can also checkout this place! Worked for me, you might also get some helps here http://www.cherryled.com.au/savings-calculator/ Re: LED Downlights Perth Recommendations? 6Mar 31, 2015 4:44 pm Hi, Expect to pay between $15 - $25 per light to be installed from scratch. The tradesmen will need to mark the lights out, drill the holes, after making sure there are no obstructions, wire and clip the cables, strip and fit off the downlights, and of course pack up and clean. $50 including the light is reasonable. However there are some great downlights online that are reasonably priced, and can be sent for free to your areas, meaning you can afford to spend a bit more on the installation. I hope this helps. Kind Regards, Kristin Lighting Expert Phone -1300 798 220 Email - service@golights.com.au Website - http://www.golights.com.au Re: LED Downlights Perth Recommendations? 7Mar 31, 2015 5:09 pm Hi I believe that paying about $65 should be the bare minimum you should pay for each downlight to be supplied and installed. Anything less than that would be very *******. Otherwise You will be compromising with the quality of the LED and workmanship. What I would recommend is to get an led that covers a wider angel as well as higher lumens. In many cases it would mean it down light would be a little bigger than normal but u will need less lights. Too many downlight will make the ceiling look like as if it is raining. Hope this helps. Re: LED Downlights Perth Recommendations? 8Apr 07, 2015 2:51 pm I agree $50 per light is a good price including the down lights. Can you share the contacts? Re: LED Downlights Perth Recommendations? 9Apr 07, 2015 9:05 pm My interpretation was $30 + $50??? In which case I would say that is reasonable. $50 including the light ($30 + $20) is ridiculously cheap and I don't know how a suitably licenced electrical contractor could work for prices that cheap and be able to afford to eat. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: LED Downlights Perth Recommendations? 10Apr 09, 2015 8:42 am Just be aware that the lights are of good quality. Maybe ask the electrician to show you the type he wants to install? Kind Regards, Kristin Lighting Expert Phone -1300 798 220 Email - service@golights.com.au Website - http://www.golights.com.au Re: LED Downlights Perth Recommendations? 12Jul 13, 2015 10:03 pm i am going to buy my own lights, I am thinking of getting the Sal sunny http://www.electriciansupplies.com.au/shop/index.php?main_page=product_info&products_id=3600. How much should I pay per down light install? I have 42 downlights and a few wall lights and ceiling lights. My builder said I will have to deal with the electrical contractor that do the wiring directly. Re: LED Downlights Perth Recommendations? 13Jul 14, 2015 8:32 am Assuming it is a new house, in my experience "per point" pricing is usually in the range of $50-$80. This includes wiring, switching, installation and circuitry (but does not include supply of the light fitting). Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: LED Downlights Perth Recommendations? 14Jul 14, 2015 1:02 pm 1960sModernistHome Assuming it is a new house, in my experience "per point" pricing is usually in the range of $50-$80. This includes wiring, switching, installation and circuitry (but does not include supply of the light fitting). the circuitry are already there even the dimmer switch are provided by the builder are in my contract. He only have to install the light $50 - $80 is so expensive. Re: LED Downlights Perth Recommendations? 15Jul 14, 2015 1:19 pm No, $50-80 is average. I know this because I work in the industry and I used to be an electrical contractor before I became an engineer. When I was in electrical contracting we worked for a bunch of home builders and the "per point" price for a light point was $60+GST. That was 10 years ago. You can't just "install the light". If there is no cable to it it will not work. They also need to conduct mandatory testing, clean up after themselves, cut the hole, fit off the socket for the light, supply and install the cables, clips, socket.... then they have a business to run. Do you whinge to your doctor when he charges you $80 for a 5 minute consultation? Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: LED Downlights Perth Recommendations? 16Jul 14, 2015 1:44 pm 1960sModernistHome No, $50-80 is average. I know this because I work in the industry and I used to be an electrical contractor before I became an engineer. When I was in electrical contracting we worked for a bunch of home builders and the "per point" price for a light point was $60+GST. That was 10 years ago. You can't just "install the light". If there is no cable to it it will not work. They also need to conduct mandatory testing, clean up after themselves, cut the hole, fit off the socket for the light, supply and install the cables, clips, socket.... then they have a business to run. Do you whinge to your doctor when he charges you $80 for a 5 minute consultation? Do you actually ready my post? The circuitry are there even the trimmer are provided, all he need to do replace the stand light point with the down lights. I can understand that $50-$80 if they have to run from scratch. but my situation they don't. Re: LED Downlights Perth Recommendations? 17Jul 14, 2015 4:14 pm Ah right, sorry I misunderstood. I thought you meant you were adding extra points on top of your standard inclusion of points. My mistake. Back when I was in the game, our $60 per point included installation of the customer supplied lights whether they were standard lights or downlights - the time taken to install a downlight is about the same as to fit an oyster light or wall light. The only time we would charge extra was if the lights were big fancy pendants or chandeliers because they took much longer to install. Although if the electrician has already wired them for standard lights and put timber battens in, they would need to get up in the ceiling and remove the timber battens so they can drill the hole out for the downlight. This would take them a bit of time and mucking around so it would be fair for them to charge you maybe $20 or thereabouts per fitting that would be reasonable I would think. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: LED Downlights Perth Recommendations? 18Oct 02, 2015 7:31 pm Sorry for crashing the thread. I don't want to double create the post. We are also looking for an electrician to supply and install for us in Perth. We also need someone who can advice because the required number of downlight depends on the LED downlight specification. So far, I haven't had much luck of getting quotes......and the house is about to be handed over. Timeline: viewtopic.php?f=31&t=76782 Re: LED Downlights Perth Recommendations? 19Oct 08, 2015 9:08 am sofia14 Sorry for crashing the thread. I don't want to double create the post. We are also looking for an electrician to supply and install for us in Perth. We also need someone who can advice because the required number of downlight depends on the LED downlight specification. So far, I haven't had much luck of getting quotes......and the house is about to be handed over. Take your house plan to the light shop so they can help you with the lay out of the downlight. I rather buy my own downlights instead of getting the electrician install as a package. The brands that I went for are Brightgreen d900 classic and sal sunny light ecogem. I have a best deal on brightgreen d900 $58ish each x 36 and the ecogem is around $26 each. I bought d900 on ebay and the ecogem is at electrician supply website. I will get the builder electrician to install them for me. My builder allow me to deal with them directly. Hi We have finally decided to complete a KDR on our corner plot in NE Melbourne suburbs. Given its a corner plot approx. 400 sqm just a standard design may not fit the… 0 9260 Looking to start the journey of becoming an owner builder in SA. Feeling pretty (overly) confident on the building and construction details, but really struggling to find… 0 8861 |
