Browse Forums Lighting + Lighting Design 1 Dec 08, 2013 10:58 am I will have a 3 metre long kitchen island, with a kitchen bulkhead at 28 courses above it. I want two of these pendants for over the island: http://www.dunlinhome.com/products/tita ... ight-black (sorry, couldn't insert image) I have a choice of two diameters: 45 cm, or 36cm. Is 45 cm going to look too large or is it just right? While I have your attention.... If I have a dining room pendant with an 18 watt bulb, I'm going to need supplementary lighting, right? Thank you! http://www.housebythewater.wordpress.com From blank block to new home in Mandurah, Western Australia. viewtopic.php?f=31&t=65564 Re: Pendant light diameter? Getting the scale right. 2Dec 30, 2013 10:08 am I'm thinking that the 45cm times 2 is going to be a bit too big, even though you have a 3m long island bench. It does look really nice though. The dining room pendant, that's 18w cfl/led or incandescent ? if cfl/led it might be enough. What you really need to know is the amount of lumens you want for that area, and I personally don't know your build or for that matter what YOU really want. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Pendant light diameter? Getting the scale right. 3Dec 30, 2013 10:43 am I think bpratt is correct that it may be a little too big. I am sure the interior designed inclided can opine but there must be some golden ratio that is used for visual impact. I had thought that pendants are used in odd numbers. 3 of the large would cover almost half of the bench. I would probably go for the smaller ones myself and maybe use two larger ones over the dining table. I would not pay too much thought to my design suggestions either as I am struggling massively in that space..... I think it would be good to see the planned area and the other design choices selected thus far so others can chime in. Remember that ultimately you have to live with it. Cheers Mark Re: Pendant light diameter? Getting the scale right 4Dec 30, 2013 10:44 am deleted double post Cheers Mark Re: Pendant light diameter? Getting the scale right. 5Dec 30, 2013 12:54 pm Our island is 2.7m long, and we have got junction boxes in the ceiling, and plan to get 3 pendants installed after handover. We are currently looking at 3 x 40cm diameter pendants. In particular, these ones: http://micalighting.com.au/ceiling-lights/pendants-chandeliers/lea40-pendant-light.html We don't have a kitchen bulkhead though, the ceiling is 2590mm. I think with your slightly lower bulkhead, the bigger diameter might look too large, but then as you only have 2, not 3, it's hard to be sure. I understand your worry about getting it right, we've thought long and hard about ours and still aren't 100% sure. Re: Pendant light diameter? Getting the scale right. 6Feb 11, 2014 10:49 am Thanks for your help everyone. I forgot to subscribe to my own topic, so didn't notice the answers until now. I will stick with the 36 cm. As for the question about LED or incandescent, I'm not sure, I'm guessing incandescent - data sheet for product says: "Philips Ambiance, Energy Saver Globe" It's this one: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Lighting is so confusing, it's a shame I'm such a sucker for beautiful lights. http://www.housebythewater.wordpress.com From blank block to new home in Mandurah, Western Australia. viewtopic.php?f=31&t=65564 Re: Pendant light diameter? Getting the scale right. 7Feb 11, 2014 4:23 pm I absolutely LOVE those lights just above. If your dining table and kitchen are near each other, I probably wouldn't have 2 completely different styles. I would just choose either dining or kitchen bench for the feature lighting. Going back to look at your plan so I can see where your rooms are! Did I mention that I LOVE those lights! Re: Pendant light diameter? Getting the scale right. 8Feb 11, 2014 9:34 pm Good point Kristen. I was actually thinking of different lights in dining room, living room and kitchen which are all in the same space... Hmm. I actually reckon I can get away with it, but that has decided me that I'm keeping the kitchen bench pendants to just two, so they are not positioned too close to the dining room. I think I'll have to do some a mood board soon for these three rooms together, to make sure I'm not creating clashes. http://www.housebythewater.wordpress.com From blank block to new home in Mandurah, Western Australia. viewtopic.php?f=31&t=65564 Re: Pendant light diameter? Getting the scale right. 9Feb 18, 2014 3:33 am Remember also that the pendants will cast light in a cone. That means the size of the circle of light that cone casts on your bench top will be a function of the size of the fixture and how high above the bench top it hangs. You want those circles to intersect pretty substantially, or you'll have odd dark spots in your work area... Chris On the threshold of retirement... and trying to check my assumptions at the door Re: Pendant light diameter? Getting the scale right. 10Feb 18, 2014 4:10 am Thanks ChrisE. Gets more complicated by the minute! So any clues for this scenario: 3 metre bench, choice of 36 cm diameter or 45 cm diameter pendant (same pendant), bench height standard 940mm, ceiling height 28 course bulkhead (2.4 m), probably needs minimum 50 cm length for hanging. (Couldn't post pic, so here's the link: http://www.dunlinhome.com/products/tita ... ight-black) My husband and I had the pendant up on the telly screen yesterday, enlarged to real size and our measuring tapes out to show bench length. We thought 2 pendants were enough, but we didn't think about light output/shadows. Back to the drawing board.... ( Might have to go for a more delicate pendant and move to 3.) http://www.housebythewater.wordpress.com From blank block to new home in Mandurah, Western Australia. viewtopic.php?f=31&t=65564 Re: Pendant light diameter? Getting the scale right. 11Feb 20, 2014 5:01 pm Good info there guys. I would use 3x pendants. 1x would be directly in the centre of the bench, and the other 2x about 900mm in from the edge, maybe less depending on how it looks. Its hard to gauge if you can't see it. But I would definitely go for 3x if you are using this as your main light over the bench. If you have other lights that will switched on while cooking/preparing, then you can get away with 2x pendants (any size) because the other lights will provide ample lighting. Hope this helps Kind Regards, Kristin Lighting Expert Phone -1300 798 220 Email - service@golights.com.au Website - http://www.golights.com.au Re: Pendant light diameter? Getting the scale right. 12Feb 20, 2014 8:40 pm housebythewater Thanks for your help everyone. I forgot to subscribe to my own topic, so didn't notice the answers until now. I will stick with the 36 cm. As for the question about LED or incandescent, I'm not sure, I'm guessing incandescent - data sheet for product says: "Philips Ambiance, Energy Saver Globe" It's this one: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Lighting is so confusing, it's a shame I'm such a sucker for beautiful lights. Love these lights. If you don't mind, can you please tell me where you got them from, and the name of the lights? HD Re: Pendant light diameter? Getting the scale right. 13Feb 20, 2014 10:04 pm Thanks for your advice Go Lights. 4evaesh - the are called coco pendants, by Coco Flip. If you check out their web site you can find suppliers for each state. I adore them. They are not cheap though - but true works of art/amazing craft. Aussie made! http://www.housebythewater.wordpress.com From blank block to new home in Mandurah, Western Australia. viewtopic.php?f=31&t=65564 Re: Pendant light diameter? Getting the scale right. 14Mar 16, 2014 4:45 pm You're welome! We also have these lights for sale, so If you have an y questions about them, please let us know, and we can help. Kind Regards, Kristin Lighting Expert Phone -1300 798 220 Email - service@golights.com.au Website - http://www.golights.com.au Re: Pendant light diameter? Getting the scale right. 15Aug 02, 2014 5:57 pm Those are gorgeous lights <3 Re: Pendant light diameter? Getting the scale right. 16Jun 28, 2016 11:09 am housebythewater Thanks ChrisE. Gets more complicated by the minute! So any clues for this scenario: 3 metre bench, choice of 36 cm diameter or 45 cm diameter pendant (same pendant), bench height standard 940mm, ceiling height 28 course bulkhead (2.4 m), probably needs minimum 50 cm length for hanging. (Couldn't post pic, so here's the link: http://www.dunlinhome.com/products/tita ... ight-black) My husband and I had the pendant up on the telly screen yesterday, enlarged to real size and our measuring tapes out to show bench length. We thought 2 pendants were enough, but we didn't think about light output/shadows. Back to the drawing board.... ( Might have to go for a more delicate pendant and move to 3.) What size did you end up using? I too only want to use 2 larger size pendants over our island which is only small at 2.4m but we have high ceilings at 3.1m. Fell in love with the coco too but can't afford it so just going the replica polk. It comes in 30cm and 46cm diameter and I'm totally stuck on what will look "right"!! Re: Pendant light diameter? Getting the scale right. 17Jun 29, 2016 12:12 am We used two 45cm Titan pendants from Dunlin. Our bench is 3m x 1.2m Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ . I think it's worked out just right. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ http://www.housebythewater.wordpress.com From blank block to new home in Mandurah, Western Australia. viewtopic.php?f=31&t=65564 Re: Pendant light diameter? Getting the scale right. 18Jun 30, 2016 10:23 am I think they look perfect Great choice! Our island is much smaller at 2.4m x 1100m so I don't think the 46cm will work but our ceilings are 3.1m so the next size down 30cm might be too small ( i really want just two not the common look of three pendants) I really need a size in between I think!! Arrr so frustrating! Re: Pendant light diameter? Getting the scale right. 19Jun 30, 2016 9:53 pm Ooh. That ceiling height is a bit tricky. If you are feeling brave, I think two pendants hung at different heights would look great, especially if they were hung off centre, as a "group". http://www.housebythewater.wordpress.com From blank block to new home in Mandurah, Western Australia. viewtopic.php?f=31&t=65564 I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17537 They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5830 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 9529 |
