Browse Forums Lighting + Lighting Design 1 May 10, 2011 8:44 pm Can downlights be installed on the lower floor? Safely? Even if there is between floor insulation? What is the best way to cut out holes in insulation, without ripping out the ceiling? Re: Installing downlights in a double storey house 2May 10, 2011 9:17 pm You do realise that you need wiring before actual light fitting. Re: Installing downlights in a double storey house 3May 10, 2011 9:27 pm Ah yes, sorry. The wiring is in place. Or rather was put in place during the build. Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 12798 1 4795 The price you're seeing for a high-spec 2-storey home in Perth sounds steep, but unfortunately, it's kind of the norm these… 8 9985 |
