Browse Forums Lighting + Lighting Design 1 Mar 20, 2024 1:07 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Having stair wall lights like this installed in new build, but 2 for each flight and 2 on landing. The stair case door will be moved forwards to the same level as the first step so it will be more closed in. If I get a sensor fitted where I put the red dot, would it work to turn on the stair wall lights? The electrical person that was doing the electrical plan for me didn't seem to like the idea Re: Motion sensor for stair wall lighting 2Mar 20, 2024 3:33 pm andy8 The electrical person that was doing the electrical plan for me didn't seem to like the idea I'm curious, did they provide any reason why they did not like the idea? -= Are you still using a notebook or spreadsheet to keep track of your customers and appointments? You need Simple Time Planner - Free Appointment Software =- Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29403 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9311 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 9001 |
