Browse Forums Lighting + Lighting Design Re: Facade Lighting - up/down lights vs downlights 3Feb 22, 2021 8:20 pm Follow my build here: https://www.instagram.com/ivy5custom Re: Facade Lighting - up/down lights vs downlights 6Feb 23, 2021 3:28 pm Follow my build here: https://www.instagram.com/ivy5custom Re: Facade Lighting - up/down lights vs downlights 8Feb 25, 2021 10:48 am You have a similar façade to us. We did up/down lights on the posts, a downlight at the front door and a spotlight (same design as the up/down light) over the driveway. We love the effect we get. They are on 3 separate switches. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We also did downlights down the sides of the house, so it's not dark if you go out there at night time. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29146 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9151 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8840 |
