Browse Forums Lighting + Lighting Design 1 Aug 21, 2020 2:05 pm Hi all, I’m planning to get the builder to do standard batten lights/minimal downlights and a sparky to come in post handover to do the remainder for a 3x2. As such, I’m trying to figure out how much I’d need to budget for/save. How much did this cost to do (if you did the same)? I can’t figure out if a light is too expensive or not. (Ie a nice wall light for bedroom is $150 each which seems ok but it all adds up, is that too much to spend or is it standard?) Thanks in advance. Coming back to your old stomping grounds, huh? Renovations on a budget can be quite the journey. It's like giving your house a new lease on life. The twist of not knowing… 1 3625 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29149 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9153 |
