Browse Forums Lighting + Lighting Design Re: Joint room, same or different lights? 21Jan 10, 2011 8:24 pm Thank you! Lots to think about. Will go "light" cruising next week. Will let you know what I choose. www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com Re: Joint room, same or different lights? 22Jan 17, 2011 1:39 pm What did you decide in the end themax? Are you thinking of a pendant light in the dining room and downlights elsewhere? Or another combination? Re: Joint room, same or different lights? 23Jan 17, 2011 2:37 pm bbb, I haven't actually decided yet. I am a bit of a procrastinator. I know when I see them that is what I want. Thanks for asking though and I will be sure to update this thread. www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com Re: Joint room, same or different lights? 24Jan 17, 2011 2:42 pm We've got a huge open living area and are planning to have downlights everywhere. We will however make provision for a pendant light in the centre of where we plan to have our dining table. We are also having ceiling fans (with light) in lounge and family rooms (all a part of one open living space). Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4752 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2865 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5407 |
