Browse Forums Lighting + Lighting Design 1 Nov 23, 2015 1:28 pm In my new apartment, in the master bedroom there is one single light fitting at the moment, with a rather odd chandelier. I want this gone and in its place, EITHER a really nice ceiling fan with light, OR a ceiling fan and another second light elsewhere on the ceiling. But is this possible? To have 2 separate fittings like this if only one currently exists? Re: One existing light fitting in ceiling...can two lights w 2Nov 23, 2015 2:18 pm If you have a light that's separate from the fan, then you need to have it a reasonable distance away so that you don't get flickering light as the fan blades cut in front of the light. In many cases that would be putting the light away from the centre of the room. The easiest solution is to replace the existing light with a remote controlled fan/light. This is a simple exercise, and will just use the same wiring. Depending on the ceiling construction, it may be possible to pull a cable across to another location, but it is a more difficult job. Then it's trickier still to run that through to another switch on the wall. Re: One existing light fitting in ceiling...can two lights w 3Nov 23, 2015 3:38 pm Cool, thank you so much! I think fan and light combo it is (the ceiling is vermiculite and we don't want to mess with it! lol) "is it exempt or do I need to get permission from council" Call your Council and ask them 1 2181 Which ceiling hook to use to hang Xmas lights under Eaves in 1st floor in 2 storey façade (no… 0 1462 I am currently doing a bathroom renovation and want to put in a window that is narrow than the current one in a brick opening. Can I fit the window on the bottom noggin… 0 516 |
