Browse Forums Lighting + Lighting Design Re: Help with down light plan 24May 20, 2015 2:14 pm Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Help with down light plan 29Aug 06, 2015 2:03 am Our Honeywood Build Hey Beazley! We have the light fittings already (brought them online) but our house is not at handover yet so the lights aren't installed. We went with white rimmed brightbreen D900's throughout. I loveeeee the star lights and wish we got them but might be a add on later idea once we have covered all the other stuff we need to finish first. Our kitchen pendants are white too and I think white is a bit more blending with the ceilings and not standing out. I also think white fascia goes better with the soft textured neutrals which is the style we are going. I could imagine that silver would suit more of an industrial styled home. I think you're right about having the light as close to the mirror as possible and even slightly angled into/towards the mirror so light is reflected onto your face rather than straight down to the floor. Star lights should have good effect and if you have spoken to lighting stores/professionals then I'd say it will work out well Where online did you buy, sounds you've done your research.. My thread - viewtopic.php?t=77170 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 14446 we need accurate dimensions as well as the number of bedrooms and bathrooms needed etc to make specific suggestions but, based on estimated rooms sizes, it could be… 1 1287 You need to locate those 2 manholes ( the black circles) and run a string line between them They may be covered in dirt or plants but do some hunting and you will… 1 1485 |
