Browse Forums Old Home Restoration / Renovation 1 May 04, 2022 9:22 pm I'm looking at cutting out openings in a single skin brick wall and install lintels and windows. Given lintel bearings need to be 150mm minimum and to maximise my window sizes I was looking at fixing 2x long lintels (4m long including 150mm bearing each side) that would be continuous spans (with a short brick pier in the middle (1 course wide) - rather than fixing 4x lintels. Does anyone see an issue with that?.. a bit like floor joists running over a number of bearers, rather than being single span. Thanks in advance Re: Steel lintels 2Dec 27, 2022 10:36 pm How did you go with this? If your still thinking about it, I would look into steel lintel expansion. I suspect it wont be an issue at 4m in length. Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14769 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4645 That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 18396 |
