Browse Forums Old Home Restoration / Renovation 1 Aug 29, 2021 9:08 am We purchased a property where the previous owners had constructed an atrium / pergola structure around the front entrance made of timber, plywood and cladded with cement sheet. There is no weather proofing on the framing. I'm looking for advice... Should there be flashing, ridge capping or even just a painted-on membrane? Any and all advice welcome thanks! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Advice on weather proofing 2Aug 29, 2021 12:52 pm It's a little hard to make it all out from the photos but normally you would have flashings bent up that cover the top of the openings. If you paint it with a membrane you will effectively make a dam on top. It will fill with water and sit there. The membrane will fail and you'll have issues. It looks like the job was never really finished and is poorly done. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Advice on weather proofing 3Aug 29, 2021 3:14 pm Thanks mate. Here's some better photos. The guy that put this up did a lot of his own stuff, as I'm discovering. The narrow wall top (110mm) should be easy enough to put some flashing over, just not sure how to deal with the wider one which is 300mm. You can just about see he's left gaps between the cladding and the frame to let water escape. I don't want to tear it all down, ideally can find some suitable flashing or ridge top to use. Any suggestions welcomed 😊 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 21007 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16786 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7742 |
