Browse Forums Flooring & Floor Covering 1 Jul 11, 2019 4:49 pm Can some one please recommend a good place t get carpet from to replace existing carpet at our new place? I visited Carpet Court and got a quick quote of $65 for square meter for Tamarind Park installed with underlay + $5 per sq meter for removing the carpet. Also do you have favorite Capet that you like to recommend too? 1 16503 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6987 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 8208 |
