Browse Forums Flooring & Floor Covering 1 Mar 27, 2019 6:57 am Hello, My partner & I are building our first home and are tossing up between the Kenbrock Vinyl planks in the radiant spotted gum or warm spotted gum and the heartridge Nevada plain. Has anyone used either of these that has some photos they can share? Thank you. Re: Kenbrock vs Heatridge Vinyl Flooring 2Mar 27, 2019 8:21 am [quote="TaylaandBrenton"]Hello, My partner & I are building our first home and are tossing up between the Kenbrock Vinyl planks in the radiant spotted gum or warm spotted gum and the heartridge Nevada plain. Has anyone used either of these that has some photos they can share? Thank you.[/quote I am also looking at the Heartridge range also, however in Sahara Dune, which is more of a sandy colour than the Nevada Plain. Have you compared all 3 planks side by side? Both the Kenbrock planks you are considering appear to be a darker tone than the Heartridge Nevada Plain, which also has different markings/pattern as it is an ‘oak’. Also the variation is limited with Heartridge as there are only 5 different planks in each pattern so when installed on your floor will see more repetition of the same planks. I’m not sure how many Kenbrock has. Re: Kenbrock vs Heatridge Vinyl Flooring 3Mar 27, 2019 9:01 am TaylaandBrenton Hello, My partner & I are building our first home and are tossing up between the Kenbrock Vinyl planks in the radiant spotted gum or warm spotted gum and the heartridge Nevada plain. Has anyone used either of these that has some photos they can share? Thank you. See images posted by me earlier for Karndean Mountain Spotted Gum Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8821 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15559 |
