Browse Forums Flooring & Floor Covering 1 Jul 17, 2018 1:45 pm I'm torn between these two products, I'm leaning more towards solid but most flooring stores seem to push the engineered flooring more. I plan to have either choice stuck down with sand & polish finish to cost going with solid from engineered is not that big. Has any had any major issues with engineered timber? Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16737 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6703 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8876 |
