Browse Forums Flooring & Floor Covering 1 Jul 04, 2016 7:35 pm Just curious, what do people do with the flooring in the linen cupboard and a store for example, a store under the stairs? If I am putting timber, should I be putting timber in there too or just seal the concrete? Feels a bit of a waste to be putting timber in a store/storage area. For wardrobes in the bedrooms, if carpets are going in, I am guessing it would make sense to just carpet that area. Also would you put skirting in a linen/store/wardrobe? Re: Flooring in linen/store 2Jul 05, 2016 12:03 pm I personally would be putting floor coverings into the store room and wardrobes. We have a store room and it has carpet, linen in laundry has same tile flooring and wardrobes have carpet. Builders put skirting etc into all cupboards/wardrobes Re: Flooring in linen/store 3Jul 12, 2016 3:07 pm built in robes, linen, cupboard are fine, but not storage room under the stairs. Do you really want to accommodate the window? What is on the outside of the window? Do you want to be able to see your towels from outside? I would blank the window from… 2 10495 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6802 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16758 |
