Browse Forums Flooring & Floor Covering 1 Oct 26, 2014 12:06 pm Hi all, Just seeing what others have used in their living areas - matte or gloss tiles?? I am about to start my build and tossing up between the two. Gloss looks nice, but apparently requires more cleaning and maintenance - not ideal for a 26yo single male! Matte apparently does not require cleaning as frequently and is a bit less slippery. Over to you! Did you choose gloss or matte tiles to your living areas and why?? Thanks! Dale Dale - Building Newbie Proserpine, QLD Re: Matte or Gloss tiles to living areas? 2Oct 26, 2014 3:34 pm Hi Dale. I had gloss tiles in my last house and they were extremely high maintenance. I would go matt if I had to choose again. Or I I would get one of those roomba vacuums. With the gloss, if you walk around in bare feet, it leaves footprints etc. Just another top too - think about sealing the grout as it gets filthy if you mop regularly. Most builders don't include this. For my current house I went with a tile that's matt but has a gloss type pattern through it. It doesn't leave any foot or hand prints but it's just in the bathrooms. Re: Matte or Gloss tiles to living areas? 3Oct 27, 2014 3:35 pm Thanks Joan, much appreciated! I think I will go with the matte - anything that is less maintenance gets the tick of approval from me Dale - Building Newbie Proserpine, QLD Re: Matte or Gloss tiles to living areas? 4Oct 27, 2014 3:44 pm Gloss look stunning, but to keep them that way takes a lot of work... but then again if you are out at work all day and have no pets then they should stay fairly clean with one mop a week. That said I wouldn't want gloss in my house unless I had a cleaner coming in daily to make sure they stay pretty... I certainly wouldn't want to put in the effort it takes to keep the gloss tiles looking nice. My build: viewtopic.php?f=31&t=68002 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1699 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6713 This link might answer your question. I had the same issue and it turned out to be the roller. https://www.sherwin-williams.com/painti ... %20coating. 4 18169 |
