Browse Forums Flooring & Floor Covering Re: I work at Carpet Court - do you have a flooring question 321Oct 16, 2015 7:40 am Thats a good price!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 322Oct 18, 2015 10:41 am Hi...I'm just starting to look at flooring options for downstairs (dining/kitchen/living). If we want a high end result should we be looking at real timber floors, as opposed to engineered wood? I read that real timber can shrink etc and our builder (salesperson) also put me off them and suggested that engineered wood was the way to go ( but maybe that's what he wants to supply, I don't know?!). Also, I asked the builder about the cost difference between travertine and engineered wood and he said they were both about the same as travertine tiles are expensive to lay because they need screeding first. Is this all correct? Sorry so many questions....so confusing! Re: I work at Carpet Court - do you have a flooring question 323Oct 18, 2015 2:30 pm Hi lazandjohn, If you have the option, go real timber flooring any time! But remember...NO steam mops on either!! Tiles and timber are 2 totally different looks. It really depends on the look you are aiming for. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 324Oct 18, 2015 9:38 pm Hi. I'm looking for cork underlay to use under bamboo, but I'm having trouble finding it. What most offer is a strange mix of rubber with some cork flakes for a gigantic price of upto 20 bucks a sq.m. Is there a place I can get it in Australia, preferably Adelaide, or should I order it from overseas and not try my luck at the local market? Thank you for your help. Re: I work at Carpet Court - do you have a flooring question 325Oct 19, 2015 5:09 am I'll check at work today for you... Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 326Oct 19, 2015 5:59 pm barnes Hi. I'm looking for cork underlay to use under bamboo, but I'm having trouble finding it. What most offer is a strange mix of rubber with some cork flakes for a gigantic price of upto 20 bucks a sq.m. Is there a place I can get it in Australia, preferably Adelaide, or should I order it from overseas and not try my luck at the local market? Thank you for your help. Barnes, Check out the link below, they sell 3ml cork underlay for floating floors. I can't find it on their site maybe you have more time. If not give them a call or ask your local flooring store to see if they can get it. The rubber mix is the best one to get though. http://www.premiumfloors.com.au/brands/ ... cessories/ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 328Nov 09, 2015 7:18 pm Got a floating floor? Got a steam mop? Get rid of it now! Take a look at the photos I have put together for you to see....the third photo is water and steam damage from a steam mop or excess water use on the floor. This applies to ALL floating timber floors. Bamboo, Laminate and Timber. In fact, get rid of your steam mops, they are bad for most floors! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 330Nov 10, 2015 4:59 am Hi Jinx, I don't recommend steam mops for anything other than tiles or concrete. Glue down vinyl planks - the heat from the steam could make the glue release making the planks come up. We don't sell anything that I would recommend using a steam mop on. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 332Nov 23, 2015 8:39 am Hi , i am planning on laying vinyl planks (loose lay floating) in our downstairs area, which is currently covered in tiles. Has anybody had experience laying over tiles? the area is about 80m2 so i don't want to be removing tiles! i was thinking maybe getting some grout or mortar to top up the grout lines, and level off. Is this needed? There are a few high spots in the tiling, so i will need to hammer them out and fill in with mortar. i have been getting different responses from different shops, so i am really confused! Some say yes just lay over, others say i need to fully remove tiles Any advice would be appreciated Re: I work at Carpet Court - do you have a flooring question 333Nov 23, 2015 10:10 am Hi Michelle, help please: we just got bamboo floors laid down in bedrooms and is very noisy when you walk on it in some parts of the room is this normal and will stop with the time? Thanks in advance Re: I work at Carpet Court - do you have a flooring question 334Nov 23, 2015 4:59 pm inferno6688 Hi , i am planning on laying vinyl planks (loose lay floating) in our downstairs area, which is currently covered in tiles. Has anybody had experience laying over tiles? the area is about 80m2 so i don't want to be removing tiles! i was thinking maybe getting some grout or mortar to top up the grout lines, and level off. Is this needed? There are a few high spots in the tiling, so i will need to hammer them out and fill in with mortar. i have been getting different responses from different shops, so i am really confused! Some say yes just lay over, others say i need to fully remove tiles Any advice would be appreciated If your laying the loose lay vinyl planks, they go right over the tiles no need for filling in the grout lines. You can't do this with the glue down planks, the tiles should come up. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 335Nov 23, 2015 5:09 pm Assh Hi Michelle, help please: we just got bamboo floors laid down in bedrooms and is very noisy when you walk on it in some parts of the room is this normal and will stop with the time? Thanks in advance Hi Assh, is the noise from squeaking boards when you walk on them, or is just the drum of the planks? Are they laid over a slab or chipboard and your off the ground with the your sub floor? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 336Nov 24, 2015 6:46 am Thanks Michelle. the answer i was hoping for!! What are some of the brands to consider? Re: I work at Carpet Court - do you have a flooring question 337Nov 24, 2015 6:50 am inferno6688 Thanks Michelle. the answer i was hoping for!! What are some of the brands to consider? Karndean. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 338Nov 24, 2015 2:58 pm Michelle Assh Hi Michelle, help please: we just got bamboo floors laid down in bedrooms and is very noisy when you walk on it in some parts of the room is this normal and will stop with the time? Thanks in advance Hi Assh, is the noise from squeaking boards when you walk on them, or is just the drum of the planks? Are they laid over a slab or chipboard and your off the ground with the your sub floor? Hi Michelle, Yes, when you walk on them. They are on second floor laid over chipboard. But it is not all over the room just in some places. Thanks Re: I work at Carpet Court - do you have a flooring question 339Nov 24, 2015 6:28 pm Assh Michelle Assh Hi Michelle, help please: we just got bamboo floors laid down in bedrooms and is very noisy when you walk on it in some parts of the room is this normal and will stop with the time? Thanks in advance Hi Assh, is the noise from squeaking boards when you walk on them, or is just the drum of the planks? Are they laid over a slab or chipboard and your off the ground with the your sub floor? Hi Michelle, Yes, when you walk on them. They are on second floor laid over chipboard. But it is not all over the room just in some places. Thanks 14mm Bamboo? Laid by you or from a store? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 340Nov 24, 2015 6:43 pm Michelle, what do you recommend to clean vinyl plank flooring? Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 40212 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10255 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 4441 |
