Browse Forums Flooring & Floor Covering 1 Jun 22, 2012 1:36 pm We are in need of some advice regarding which direction to lay our floorboards. A couple of weeks ago we selected our flooring and picked out some tiles for the kitchen/dining area and timber flooring (Merbau) for the living areas. The thing we had not considered when planning the house was the direction we wanted the floorboards laid. It had actually not occurred to us at all that this needed consideration. But because our house is build around the corner and therefore has angles in it, that creates some issues. We do not want to change direction of the floorboards from one area to another so we have to pick a direction and keep it up throughout the house. We thought we had it worked out, but lately have had second thoughts. I've drawn up the two options we are tossing up between to get a better visual impression: Option 1: run the floorboards with the angle of the entry: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Option 2: run the floorboards perpendicular to the angle of the entry: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ At this stage we are a bit undecided which one would look better. Does anyone here have any ideas or tips on what the best direction is for laying floorboards? Thread: viewtopic.php?f=31&t=52680 SiteStart 19/11/11 Slab 10/12/11 Frame 17/02/12 Roof 3/05/12 LockUp 22/06/12 Handover 31/08/12 Re: Laying Floorboards - which Direction??? 2Jun 22, 2012 2:33 pm It's funny that this post is here now - I was just out at our build talking with a flooring guy about which way to lay out floorboards . I like the first direction.....wide across the entry to give the "Illusion" of extra width......but hey, what do I know as our flooring guy suggested the opposite to what I had in mind originally (May have meant more work for him I suspect ) Owner Building on 1800sqm Sanity Intact so far Locked up March 2012 Re: Laying Floorboards - which Direction??? 4Jun 22, 2012 3:02 pm I've already posted my opinion on your build thread, but hey, when have I been known to hold back from posting? Option 2 so that the eye is lead to the windows as you enter the rooms. Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Laying Floorboards - which Direction??? 5Jun 22, 2012 4:46 pm Deemaree I've already posted my opinion on your build thread, but hey, when have I been known to hold back from posting? Option 2 so that the eye is lead to the windows as you enter the rooms. I think option one is better because of the entrance/hall way, the rooms will be filled with furniture to distract the eye, but in the entrance with no furniture you want to be lead along the hall way. Re: Laying Floorboards - which Direction??? 6Jun 22, 2012 5:26 pm The general rule of thumb is the hallway needs to run length ways, but in your case the general rule of thumb is thrown out the door ! Option 1 tends to lean towards this theory more than option 2 though. Just to contradict this though, the 2nd rule is to try to run the boards the longest direction in your main living areas.... Option 1 by a nose. You will have a fair degree of wastage on this floor either way. CALL 1300GOHARVEY www.harveynormanflooring.com.au Carpet, Rugs, Timber, Bamboo, Laminate, Vinyl & Vinyl Tiles TIMBERMAX Real Australian Hardwood Flooring IN STORES NOW Re: Laying Floorboards - which Direction??? 7Jun 22, 2012 8:43 pm Thank you for your opinions everyone. The flooring people we are buying from suggested Option 1 as well. But I am leaning more and more towards option 2. That way the floorboards will run into most of the rooms and also towards the windows which I think will be better. Still not entirely sure though as the "professionals" seem to prefer option 1. Thread: viewtopic.php?f=31&t=52680 SiteStart 19/11/11 Slab 10/12/11 Frame 17/02/12 Roof 3/05/12 LockUp 22/06/12 Handover 31/08/12 Re: Laying Floorboards - which Direction??? 8Jun 22, 2012 8:47 pm Only by a nose..... Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Laying Floorboards - which Direction??? 10Jun 22, 2012 9:16 pm ^^ Exactly. Sleep on it and go with what feels right for you. Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 32569 Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4532 I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 2717 |
