Browse Forums Flooring & Floor Covering 1 Aug 22, 2011 11:01 am I have been told that when a solvent based poly finish gets in contact with the adhesive a chemical reaction happens which causes bubbling. Is this true? The reason I ask is because in some spots (where it was unavoidable to walk over while the glue was still setting) glue has seeped out from in between the butt joints. We troweled the glue on by the way. I know that sanding will get rid of any excess glue from top of the surface but I guess it will still be there between the boards... Will this cause bubbling? Or is this only an issue if a coating is applied before the glue has had a chance to dry properly? Hi We are building in the Hunter Valley, our soil test is H1, our builder has advised us they need to have a letter signed for Fair Trading as the new drainage standard… 0 3762 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 2379 4 15678 |
