Browse Forums Flooring & Floor Covering 1 Nov 23, 2007 4:25 pm To anyone who has has laid boards. We are putting the click laminate boards in the new house. The guy at the shop has said instead of using a jigsaw and cutting th board to the door frame shape that you can just under cut the door frame and slot the board underneath with just a 90 angle in the board. Anyone done this, I just can't picuture how this works and how to get that last board in place as it needs to be leavered in won't the door famr just get stuck on it when you try to leaver it in place. Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 Re: boards and door frames 3Nov 23, 2007 10:20 pm really should have checked before i posted. Ah hem let me try again.
To anyone who has laid boards: Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 10612 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8896 |
