Browse Forums Flooring & Floor Covering 1 Jun 06, 2010 9:14 pm Our house is nearing completion and I am wondering about cleaning the slab before putting the floor coverings down ? Do people bother to do that ? Do the carpet layers have something that does it ? We are putting down a mix of timber and carpet. I would like to try to get it as clean as possible, I was thinking of renting a wet /dry vacuum cleaner. Any ideas or suggestions Re: Cleaning concrete slab before floor coverings ? 2Jun 06, 2010 9:20 pm dust is always going to come up from concrete no matter how many times it is cleaned unless it has been sealed. . Just make sure you remove all the lumps and bumps in preperation for any type of floor covering. Re: Cleaning concrete slab before floor coverings ? 3Jun 06, 2010 10:38 pm Doug - if the floor is dusty you might like to seal it. otherwise don't worry. Where you are coming from is where you are going to... Re: Cleaning concrete slab before floor coverings ? 4Jun 06, 2010 11:05 pm Before carpets are laid, it is important that floors are clean. But MOSTLY that they are smooth and flat. Any lumps and bumps should be cleaned and scraped off, the floor dry vacuumed and the floors checked for flatness. A good dry vacuum should be sufficient. Its not imperative, but you could seal the floor beforehand to bind up any dust. As a carpet cleaner, I often find dust coming up around the edge of carpets which is a PITA! It is sometimes timber from where skirtings have been fitted, and sometimes concrete dust. So when the layers are on the job, be sure to see that its vacuumed around the room perimeters before the carpets are laid. Ash. Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4361 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4944 Hi there I'm looking for a independent company for a expert report on my blinds ,sheers & plantation shutters I'm in Melbourne 0 9274 |
