Browse Forums Flooring & Floor Covering 1 Oct 03, 2007 10:54 am It's funny that every time I tell someone I wont be using glue, they're amazed and advise against it (not that they're experts). So often that it concerns me now.
I'm installing it in all the bedrooms, living room, and rumpus. These aren't areas where I should be worried about water spillage, but I know it's bound to happen. Should I be concerned with liquid seeping into the joints? Thanks Re: No Glue Laminate Flooring 2Oct 03, 2007 11:24 am I happen to be one of those non-experts. But just curiuos as to why you're not using glue? [sneakersss] Re: No Glue Laminate Flooring 4Oct 03, 2007 11:58 am Oh right. You're having one of those click laminate flooring as opposed to the others that just have a tongue and groove system?
Either way (and still no expert) I think the glue would be more for the purposes of securing it further rather than acting as a seal?! So if one was really worried about spills on the floor and it seeping through then maybe sealing the actual floor would be the best option. [sneakersss] Re: No Glue Laminate Flooring 5Oct 03, 2007 5:31 pm we have these in a rental property that we were in for 2 1/2 years i spilled stuff and it never caused a problem with the boards, i just cleaned up straight away Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 Re: No Glue Laminate Flooring 6Oct 04, 2007 8:07 am That's true, cleaning up straight away is the natural thing to do and laminates can handle that. Then we thought of our dog! She rarely does it but sometimes we do come home/wake up and she's done it inside.
Anyway I found something promising last night called Click Seal. It's applied like glue at the joints during installation. Unlike glue it's not permanent, so you can still unclick the floor for whatever reason. Re: No Glue Laminate Flooring 7Oct 04, 2007 9:13 am I've asked this question so many times (to people that are in the profession as well), to glue or not to glue, & about 80 % say to go with the click lock / uni lock (no glue) system if laying on a slab.
The main reason for this is if you ever get a damaged board for what ever reason, chipped / warped / water damaged, you can pull them apart easily & replace the damaged board/s. If they are glued this is virtually impossible to do. With the systems on the market these days, the non glued method is just as good if not better that the glued. Cheers, Mike. My Blog... http://ahouseonthehill.blogspot.com/ Re: No Glue Laminate Flooring 8Oct 04, 2007 9:43 am That's comforting to hear. Perhaps some of my stress lines will disappear now.
That's a good point too. If I was bothered enough, I think I would unclick and replace. If not, I'm sure my other half will make me. Sam There is a much stronger glue than liquid nails. It's called T Rex and will stick your timber to the concrete. Cheers Simeon 1 1784 Just about completed a renovation project and hit a small issue that we didn’t see We have laminate floors now where we had tiles before (turned out it was actually 2… 0 5328 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 7313 |
